Cam Degreeing - Primary or VTEC Lobe ???
Old May 13, 2006 | 12:37 AM
Johnny_9's Avatar
Default Cam Degreeing - Primary or VTEC Lobe ???
When you degree your cam when the engine is out of the car, are we degreeing on the PRIMARY lobe?
Experts please comment !
Old May 13, 2006 | 03:50 AM
gearhead313's Avatar
25 Year Member
Default Re: Cam Degreeing - Primary or VTEC Lobe ??? (Johnny_9)
I would say, it depends on the motor, the setup and what you are doing with it.
If its just a fun street motor, you can degree the low cam lobes and be fine. If you're building a high revving drag motor or something, then I'd lock it in vtec and degree the high cam lobes.
I think if you are even going to take the time to degree them, it should be the vtec lobes anyway.
Old May 13, 2006 | 10:42 AM
IN VTEC's Avatar
Use whatever the cam spec sheet has given you the specs for. Most of the time, you'll only get the HI cam specifications, so you'll have to degree them in with the VTEC rocker arm locked. If you have both, then it'll be the same regardless of which cam lobe specs you use to degree them in.
Old May 13, 2006 | 05:35 PM
PocketRockets Racing's Avatar
vtec lobe locked.
you can measure all 3 , then you know what you have
D-Rob
Engine Management and Tuning
Apr 14, 2008 11:39 PM
Jap_Spec_Imports
Apr 13, 2008 09:47 PM
2000d16y7
Jul 17, 2007 03:01 PM
