sir cluster in a crx SI
you can find threads that cover this. OBD1 or 0 it doesnt really matter. you will need a electronic VSS and a little rewiring but thats about it.
a VSS is a vehicle speed sensor. The 88-91 hatch came with a cable driven VSS. You need a VSS from a newer vehicle in order to use the SIR cluster. The SIR's in Japan came with electronic VSS. Does that help
The sensor is located on the tranny. There is a flat spot on the rear of the tranny and the VSS is located there. You can get one from the junkyard and most likely they will give you the plug too. You will need to hard wire it in your car. There are not existing wires for a EVSS
you'll need:
-EF8 cluster w/ harness clips
-Electronic VSS
The VSS has 3 wires
-ground
-power
-signal
You'll have to run the signal wire to the back of the cluster & the ECU in order to get the speedo to work. The other 2 plugs are obvious as to where they go.
Here's a link:
http://b16a.honda-perf.org/cluster.html
Vic
-Electronic VSS
The VSS has 3 wires
-ground
-power
-signal
Here's a link:
Vic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urafag »</TD></TR><TR><TD CLASS="quote">ok cool that helps. i wud like to use the 2000 sir cluster though ... shud fit?</TD></TR></TABLE>
Yes. Try doing a search. You'd be surprised what kind of information you can get.
http://faq.ef-honda.com/index....ng=en
You're welcome
You're welcome
tc_gts
11
Nov 23, 2004 09:30 AM
bardo
17
Jan 25, 2004 08:07 PM
rasta420
15
May 10, 2002 05:15 PM
