VTEC eliminator kit. WTF?
Old May 12, 2006 | 08:50 PM
Kyoto now's Avatar
Default VTEC eliminator kit. WTF?
Recently I was reading through a magazine and saw an ad for something called a "VTEC eliminator kit". They claimed it was desinged to "Replace and eliminate the VTEC function". Why in the hell would someone go through all the time and trouble of dropping in a VTEC motor just to take out the VTEC? Why not just get an LS?
Old May 12, 2006 | 08:56 PM
cm zak's Avatar
there are people who buy gsr's or type-r's and want to get rid of vtec, why i dont know, but theres sites like non-vtec.com that are dedicated to non-vtec stuff....
Old May 12, 2006 | 08:58 PM
.brian.'s Avatar
Default Re: (cm zak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cm zak &raquo;</TD></TR><TR><TD CLASS="quote">there are people who buy gsr's or type-r's and want to get rid of vtec, why i dont know, but theres sites like non-vtec.com that are dedicated to non-vtec stuff....</TD></TR></TABLE>
the people on that site do not buy gsr or type r motors and want to get rid of vtec, they have a non-vtec motor, hence the site name.
Modified by .brian. at 1:12 AM 5/13/2006
Old May 12, 2006 | 09:02 PM
lVlemphizStylez's Avatar
Default Re: (.brian.)
vtec was designed for streetability and fuel economy...they are toda vtec killer cams because ppl want to run aggressive cam lobes outside of vtec...vtec was intended for driveability and fuel economy..remember that...
Old May 12, 2006 | 09:09 PM
BlueIntegraBoy's Avatar
Default Re: (lVlemphizStylez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">vtec was designed for streetability and fuel economy...they are toda vtec killer cams because ppl want to run aggressive cam lobes outside of vtec...vtec was intended for driveability and fuel economy..remember that...</TD></TR></TABLE>
I believe VTEC was made to have a nice torque ( ) curve and be able to make power at higher RPMs. It allows better 'breathing' at higher RPMs.
Old May 12, 2006 | 09:12 PM
Vitesse's Avatar
Default Re: (BlueIntegraBoy)
what about the vx
GSRdude's Avatar
wider powerband
vtec is just a way to run different cam profiles...one for lugging around town and getting your 29mpg...and the other for your "breathing"....ever seen the torque curve of a car equipped with the toda vtec killers?? trust me it was done for fuel economy and driveability
Old May 12, 2006 | 09:13 PM
RHDintegXsi's Avatar
im no expert but i believe they are for drag purposes only..if you notice you never really use vtec..wait let me rephrase that..your never really on the lower cam profile..by running "vtec eliminator" cams its equil. to running in vtec all the time (if that makes any sense to anyone)
Old May 12, 2006 | 09:14 PM
Vitesse's Avatar
i know i was just making a point, because u left out eco. issues for vtec use.
Old May 12, 2006 | 09:15 PM
Default Re: (SINFULintegXsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SINFULintegXsi &raquo;</TD></TR><TR><TD CLASS="quote">im no expert but i believe they are for drag purposes only..if you notice you never really use vtec..wait let me rephrase that..your never really on the lower cam profile..by running "vtec eliminator" cams its equil. to running in vtec all the time (if that makes any sense to anyone)</TD></TR></TABLE>
well wouldnt that imply that the other nonvtec lobe is for driveability and fuel economy??? if it gave the car a better torque curve they couldnt achieve from eliminating it im sure they wouldnt opt to eliminate it...
Old May 12, 2006 | 09:16 PM
Vitesse's Avatar
ssshhut up lol my bad' i'm tired.
Old May 12, 2006 | 09:31 PM
CleanLikeJdm's Avatar
Hype-R Stalker
Default Re: (metab18b)
http://passwordjdm.com/ has the kit too
Old May 12, 2006 | 11:26 PM
bks84's Avatar
Loved
like LS's and **** your moron. and its nonvtec.com w/o the hyphen.
Old May 13, 2006 | 12:42 AM
AViciousTHRUST's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
I believe VTEC was made to have a nice torque ( ) curve and be able to make power at higher RPMs. It allows better 'breathing' at higher RPMs.</TD></TR></TABLE>
bigger cam profiles will idle like **** and will run rich at low rpms,
Old May 13, 2006 | 12:59 AM
CARMA_626's Avatar
I drive a G35, it's silver, surprised?
Default Re: VTEC eliminator kit. WTF? (DA9 Purist)
Vtec Killer. As some guys mentioned, Vtec was intended to provide the best of both worlds, drivability and fuel economy while having a more performance profile during Vtec engagement.
Well, if you wanted to ditch the drivability and fuel economy factor and run an aggressive, all performance profile from 0 rpm to redline then Vtec is pointless, isnt it? That's the concept behind Vtec elimination. However, most of us rather have a nice idle and 'around the town' drivabilty than a lump idle monster...so having Vtec is blessing.
Old May 13, 2006 | 05:58 AM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DA9 Purist &raquo;</TD></TR><TR><TD CLASS="quote">Recently I was reading through a magazine and saw an ad for something called a "VTEC eliminator kit". They claimed it was desinged to "Replace and eliminate the VTEC function". Why in the hell would someone go through all the time and trouble of dropping in a VTEC motor just to take out the VTEC? Why not just get an LS?</TD></TR></TABLE>
because on race motors you want the lowest weight valvetrains(less friction losses). eliminating vtec makes the car easier to tune and it eliminates the lag with the vtec crossover, since on a race engine you dont want to have to worry about falling out of vtec.
search toda vtec killers
Old May 13, 2006 | 06:35 AM
mr.beeks's Avatar
Default Re: VTEC eliminator kit. WTF? (projectTeG)
higher stroke
higher compression
higher rpms
sounds like a monster gasping for air all the time or ( a harley bike)
so vtec is just like a trick under your sleeve when other has reached its max
vtec is just kicking in.
and like previous answer vtec is just for fuel economy not for racing purposes.
so a vtec killer cam is like running on vtec from the begining. not waiting to hit the sweet spot.
and to the other fellow that stated vtec gives you more torque...
is displacement that gives you torque.
ever wonder why the b20/vtec?
Old May 13, 2006 | 07:02 AM
It's*BOLO!!'s Avatar
Guess whos bizzack
Default Re: VTEC eliminator kit. WTF? (mr.beeks)
check these out, they are from the ITR forum
https://honda-tech.com/zerothread?id=1616733
Old May 13, 2006 | 10:38 PM
mr.beeks's Avatar
Default Re: VTEC eliminator kit. WTF? (BOLO-FTW!!)
just like a harley...
Old May 14, 2006 | 03:30 AM
jdm_bones's Avatar
That sounds sick dude! But I don't think, that I'd want that in my ride...
Old May 14, 2006 | 03:51 AM
lustedp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lVlemphizStylez &raquo;</TD></TR><TR><TD CLASS="quote">vtec is just a way to run different cam profiles...one for lugging around town and getting your 29mpg...and the other for your "breathing"....ever seen the torque curve of a car equipped with the toda vtec killers?? trust me it was done for fuel economy and driveability</TD></TR></TABLE>
29 mpg? damn...what am I doing wrong
$3.75 a gallon and I only get 25 mpg. expletive traffic
Old May 14, 2006 | 06:19 AM
Micha's Avatar
FAILWGN
Default Re: (4sd4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4sd4dr &raquo;</TD></TR><TR><TD CLASS="quote">
like LS's and **** your moron. and its nonvtec.com w/o the hyphen.</TD></TR></TABLE>
Wow, from a moderator of nonvtec.com. Haha.
Old May 14, 2006 | 08:07 AM
petergriffen's Avatar
Default Re: (Blu99teg)
another reason they have the toda vtec killer cam is for boost whe vtec engages your compression goes up and if you dont have lower compression cams it could blow your motor. if its not tuned the best
Old May 14, 2006 | 08:35 AM
mattcivic's Avatar
Default Re: (petergriffen)
like said above the vtec eliminator kits are for race guys who dont run there cars on the street makes tuning simple. and as for mpg's my crx doesnt have vtec and i just clocked it this weekend getting 35 mpg Hf baby and gas here is like 3.10 haha the best part is i got the car for free!!! i shoud do a vx swap in it instead of more power i'd just get more mpgs its just my DD
