HELP!!! fuel pump
Old May 12, 2006 | 08:43 PM
jdm206's Avatar
Default HELP!!! fuel pump
my car is a 91 civic sedan i was woundering where the fuel pump is located? I'm trying to change it because my fuel pump went out. Is it hard to replace the pump?
Old May 12, 2006 | 09:43 PM
sauceja's Avatar
Default Re: HELP!!! fuel pump (jdm206)
Should be under your back seat cushion and reachable from inside car. Maybe an hour job if your not used to it.
Old May 12, 2006 | 09:58 PM
mahatma's Avatar
Default Re: HELP!!! fuel pump (sauceja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sauceja &raquo;</TD></TR><TR><TD CLASS="quote">Should be under your back seat cushion and reachable from inside car. Maybe an hour job if your not used to it.</TD></TR></TABLE>
No
The pump itself is located near the rear of the tank. You have to lower the straps to get to it, as well as disconnect a few hoses, lines, & all the wiring.
I just put a Walbro in my sedan last weekend, 1st time replacing a fuel pump.... hate to say this but it took me damn near 5 hours start to finish.
Afterwards I wondered if I had to remove the backseat at all. Only thing to do there was unplug the harness, only the sending unit is accessible from there. Anyone know if it's really necessary to remove the backseat and unplug that stuff?? That would've saved a good hour and a half total....
Old May 12, 2006 | 10:05 PM
jdm206's Avatar
Default Re: HELP!!! fuel pump (mahatma)
ok kool thanks for the reply. Man 5 hours damn thats hella long. was it hard for you to take out the full pump? oh yeah did you drain your tank before you took out the fuel pump?
Old May 12, 2006 | 10:12 PM
mahatma's Avatar
Yeah I'm not very quick with **** I've never done before....keep crawling out to consult the manual cause I'm skeered.
I ran the car til it was almost empty since I knew I'd be doing the fuel pump. Didn't drain the tank all the way but it was easy to handle. Disconnecting & reattaching the fuel lines and gas filler neck was the biggest pain for me.
Old May 14, 2006 | 05:33 AM
sauceja's Avatar
Ok yeah that sounds right. I have yet to install my walbro. I have a hatch with no back seat so I see my sending unit then everyday. I assumed it was fuel pump.
Fuel pumps are easier to change when you have a lift. Real world with some jack stands and on your back is a little harder.
Make sure that is definately your problem before you start.
Thanks for clearing this up for him. I was not trying to mislead anyone.
EMFinite
Aug 10, 2006 05:47 AM
EJ8 GSR-T
Jan 14, 2006 07:38 AM
SQ is the SQUAD
Oct 5, 2005 01:07 PM
wumba
Apr 7, 2005 10:08 PM
tilt
11
Nov 30, 2002 08:36 PM
