anyone ever put 1st gen b16a cams in there gsr?
Old May 12, 2006 | 03:13 PM
si0385.'s Avatar
Default anyone ever put 1st gen b16a cams in there gsr?
i doubt anyone had done this unless there in the same situation i am in, i got a gsr head but no cams and 1st gen b16a cams lying around i know i will loose a little power but will it be a big big difference...
i other words should i stop putting my motor together to buy a used set of cams or wait and get the motor in and running and in a few months go out and buy a good quality set of cams?
Old May 12, 2006 | 03:24 PM
CoreyR's Avatar
Default Re: anyone ever put 1st gen b16a cams in there gsr? (si0385.)
the cams will work if thats what your worried about. all B series VTEC heads are the same. seeing as 1st gen B16 cams are the worst stock BVTEC cams ever i would save up and buy a set of cams. hell you could score some GSR cams for under $100
Old May 12, 2006 | 03:41 PM
si0385.'s Avatar
Default Re: anyone ever put 1st gen b16a cams in there gsr? (CoreyR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoreyR &raquo;</TD></TR><TR><TD CLASS="quote">the cams will work if thats what your worried about. all B series VTEC heads are the same. seeing as 1st gen B16 cams are the worst stock BVTEC cams ever i would save up and buy a set of cams. hell you could score some GSR cams for under $100</TD></TR></TABLE>
i know they will work im not woried about that im just wondering how much power im gona loose over the stock gsr cams
Old May 12, 2006 | 03:43 PM
CoreyR's Avatar
well your not gonna get an accurate answer because theres way to many variables. it would probably be in the range of 10 horse to throw out a guess.
Old May 12, 2006 | 04:43 PM
Contender25
Guest
Posts: n/a
Yeah thats what i would say.
CBURKE
14
Dec 15, 2005 09:21 AM
wpgcivic
22
Feb 3, 2004 09:59 AM
CANTFAZZDISCHIT
Aug 18, 2003 11:47 AM
1tyme
Oct 20, 2002 01:05 PM
