B16B Stroker...
Old May 12, 2006 | 01:39 PM
B16b-EJ8's Avatar
Default B16B Stroker...
Has anyone here had any experience with some of the aftermarket stroker kits out there? I'm looking to stoke out my B16b to either a 1.8 or 2.1 any thoughts or comments?
Old May 12, 2006 | 01:58 PM
97L-esVeeTeg's Avatar
Default Re: B16B Stroker... (ProjectNoob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectNoob &raquo;</TD></TR><TR><TD CLASS="quote">Has anyone here had any experience with some of the aftermarket stroker kits out there? I'm looking to stoke out my B16b to either a 1.8 or 2.1 any thoughts or comments?</TD></TR></TABLE>
For a B16b stroker to 1.8, just use rods and pistons from the b18 of your choice. If you plan to go bigger, you're better off putting your own kit together. If not, crower has a nice stroker setup.
Old May 12, 2006 | 02:15 PM
StRoKeD-B16bEj2's Avatar
Default Re: B16B Stroker... (97L-esVeeTeg)
GSR or LS crank, GSR or LS rods, or if u want aftermarket rods, Eagle rods are pretty good, and get some new CTR pistons, New rings, And Bearings. And ur good
Old May 12, 2006 | 03:01 PM
B16b-EJ8's Avatar
Thanks guys for the input...Pretty much cheaper to use OEM parts from a B18 series then?
Old May 12, 2006 | 03:23 PM
Orangecivic251's Avatar
Default Re: (ProjectNoob)
Old May 12, 2006 | 03:35 PM
junkyard racer's Avatar
Default Re: (OrangeCiviC251)
depending on what you are trying to acheive...its probably not worth the $$.
Old May 12, 2006 | 03:45 PM
sunnydeez's Avatar
Default Re: (junkyard racer)
is you're block a p72 b16b?
Old May 12, 2006 | 04:23 PM
Default Re: (sunnydeez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProjectNoob &raquo;</TD></TR><TR><TD CLASS="quote">Thanks guys for the input...Pretty much cheaper to use OEM parts from a B18 series then?</TD></TR></TABLE>
yeah depending on wat u are trying to acheive and how much you are trying to spend.
Old May 12, 2006 | 04:27 PM
rodimus's Avatar
all the spoon stroker kti for the b16b is, is an ITR crank, ITR rods, and ITR pistons.
maybe they balanced it, but whooptie-******-doo, those parts come well balanced from the factory anyways.
Old May 12, 2006 | 06:59 PM
Default Re: (EVOL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EVOL &raquo;</TD></TR><TR><TD CLASS="quote">all the spoon stroker kti for the b16b is, is an ITR crank, ITR rods, and ITR pistons.
maybe they balanced it, but whooptie-******-doo, those parts come well balanced from the factory anyways.</TD></TR></TABLE>
this is very true
Old May 12, 2006 | 09:22 PM
cptengineer's Avatar
Default Re: (PrOjEcT Ej2)
itr stuff would be cool and get a forged piston with the new comp. height.
Old May 12, 2006 | 11:42 PM
Default Re: (cptengineer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cptengineer &raquo;</TD></TR><TR><TD CLASS="quote">itr stuff would be cool and get a forged piston with the new comp. height.</TD></TR></TABLE>
true
Old May 12, 2006 | 11:44 PM
quicksilver1689's Avatar
i ♥ snails
If your changing out internals go with forged goodies while your at it for added peace of mind.
Old May 13, 2006 | 07:06 AM
RagingAngel's Avatar
Default Re: (quicksilver1689)
depending on what purpose this motor is going to serve....
cast pistons aren't going to give you any problems - as in many cases, simply buying any forged piston might prove to be more trouble than expected with piston to wall clearances to consider.
Old May 13, 2006 | 03:38 PM
b16nonoy's Avatar
b16b stroker kit made by spoon sports on inlinefour.com and it is only bout $1,200
http://www.inlinefour.com/spoon18lstro.html
that would stroke her to 1.8L
Old May 13, 2006 | 05:22 PM
rodimus's Avatar
Default Re: B16B Stroker... (b16nonoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16nonoy &raquo;</TD></TR><TR><TD CLASS="quote">b16b stroker kit made by spoon sports on inlinefour.com and it is only bout $1,200
that would stroke her to 1.8L</TD></TR></TABLE>
rip off.
Old May 13, 2006 | 05:29 PM
boosted94cx's Avatar
* B A N N E D *
why not just sell the longblock and get a GSR longblock, or an itr longblock?
seems pretty ******* stupid to "stroke" a b16b block
Old May 13, 2006 | 06:22 PM
rodimus's Avatar
Default Re: (boosted94cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted94cx &raquo;</TD></TR><TR><TD CLASS="quote">why not just sell the longblock and get a GSR longblock, or an itr longblock?
seems pretty ******* stupid to "stroke" a b16b block</TD></TR></TABLE>
maybe because he wants a sleeper?
Old May 13, 2006 | 07:02 PM
the_unknown's Avatar
GDD Lonely Krew
the only thing sleeper about it would be the lettering on the block. i dont see any other reason for keeping the b16b block.
Old May 13, 2006 | 07:14 PM
rodimus's Avatar
Default Re: (the_unknown)
personally, i would sell the ctr block too, since you can get good money for it and put together a better engine together for cheaper IMO..
but that's the only reason that i can think of unless it was just laying around and you know it's legit and in good condition..even then, you could still build a better block for cheaper..so that leads me to believe that he really wants to make a sleeper block. *shrugs*
Old May 14, 2006 | 06:06 AM
* B A N N E D *
how the expletive is that a "sleeper"/??!?!
it's a ******* honda...the only way it's even gonna remotely be quick is with forced induction...and there's no "sleeping" with that. b16b, b20b/z, b18cwhatever....who ever sees the engine is gonna know generally what's going on. even wiht my 2.1L...there was nothing sleeper about it...
Old May 14, 2006 | 06:57 AM
rodimus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted94cx &raquo;</TD></TR><TR><TD CLASS="quote">how the expletive is that a "sleeper"/??!?!
it's a ******* honda...the only way it's even gonna remotely be quick is with forced induction...</TD></TR></TABLE>
i'd rather have an all motor car in a street race than a boosted car, but yah, whatever you say guy
Old May 14, 2006 | 07:24 AM
b16_DIM's Avatar
Ive been thinking about stroking by b16a but im still learning about building, do those kits and oem conversions mentioned work on this motor too?
Old May 14, 2006 | 08:53 AM
Default Re: B16B Stroker... (d16_DIM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d16_DIM &raquo;</TD></TR><TR><TD CLASS="quote">Ive been thinking about stroking by b16a but im still learning about building, do those kits and oem conversions mentioned work on this motor too?</TD></TR></TABLE>
well the deck height on the B16a isnt the same size as B16b, B18 blocks. OEM cranks dropp right in those blocks but B16a im not sure
Old May 14, 2006 | 08:54 AM
it's a ******* honda...the only way it's even gonna remotely be quick is with forced induction...and there's no "sleeping" with that. b16b, b20b/z, b18cwhatever....who ever sees the engine is gonna know generally what's going on. even wiht my 2.1L...there was nothing sleeper about it...</TD></TR></TABLE>
nah ur car can be quick without forced induction, just have to build u knoe.
