Fuel Delivery: higher fuel pressure, or longer pulse width?
Old May 12, 2006 | 12:25 PM
RTW DC2R's Avatar
Default Fuel Delivery: higher fuel pressure, or longer pulse width?
From a tuning standpoint, is one better than the other? I would think there is probably a gray area. Which do you "max out" first? I would assume that you normally tune with a close-to-stock fuel pressure, to the point of max (safe) duty cycle, and then increase pressure at that point if possible? Or would you rather NOT tune to a safe max duty cycle, and just turn up the pressure? More pressure will also help atomization correct?
Just curious what some of our HT tuners think.
Old May 12, 2006 | 12:35 PM
postman's Avatar
Default Re: Fuel Delivery: higher fuel pressure, or longer pulse width? (clip the apex)
more pressure if you make the pw to long it will eventuaaly be off time of the piston. but you can still extend it just not that far. also depends on dwell of spark plug.
danno33
Dec 27, 2006 02:16 PM
ProjectCRXtacy
Jul 15, 2003 03:20 PM
iwouldHITit
Mar 8, 2003 09:52 PM
