vafc wiring diagram
Old May 12, 2006 | 12:24 PM
Suck my DX's Avatar
Default vafc wiring diagram
i know its a long shot but does anybody have the vafc wiring diagram for an obd0 b16
Old May 12, 2006 | 11:17 PM
soslodelsol's Avatar
Default Re: vafc wiring diagram (Suck my DX)
http://www.apexi-usa.com/vafc2.htm
Old May 12, 2006 | 11:20 PM
crxnj's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by from faq thread &raquo;</TD></TR><TR><TD CLASS="quote">
V-AFC VTEC controller -------&gt; ECU PIN location
Red & Orange wire splice/connect to A15 (yellow/black)
Green wire RPM signal splice/connect to B15 (white1)
Pink wire VTEC signal output to VTEC solenoid (green/yellow)
Purple wire VTEC signal input not used on PM6 ecu
Blue wire VTM signal not used on PM6 ecu
Gray wire Throttle signal splice/connect to C7 (red/blue wire)
Yellow wire Pressure signal output cut/connect to C11 ECU side harness
Si/Hf = white1 , DX = orange
White wire Pressure signal input cut/connect to C11 ENGINE side harness
Black wire Ground splice/connect to A16 (brown/black wire)Engine side harness
Brown wire Ground splice/connect to A16 (brown/black wire)has to be connected closer to the ECU
Old May 14, 2006 | 04:57 PM
Suck my DX's Avatar
Default Re: vafc wiring diagram (soslodelsol)
thanks
(760)doogie
Jun 22, 2008 08:29 PM
MotoCARR
11
Dec 21, 2006 01:03 PM
aces1980
Aug 1, 2004 10:05 AM
chrisir19
Sep 23, 2003 08:42 AM
