How much tire pressure should i put in my tires????????
Old May 12, 2006 | 09:35 AM
integracura's Avatar
Default How much tire pressure should i put in my tires????????
I have 205/40/17's.
Old May 12, 2006 | 09:40 AM
Azn Kenny's Avatar
Look in your door jam.
Old May 12, 2006 | 09:41 AM
Lan's Avatar
Lan
Default Re: How much tire pressure should i put in my tires???????? (integracura)
35 front 33 rear
but does it matter, i have low profile kuhmo tires with 17" rims.
Old May 12, 2006 | 09:45 AM
Rcp's Avatar
Rcp
I thought it was 33 front and 35 rears? Someone correct me if i'm wrong.
Old May 12, 2006 | 09:48 AM
Lan's Avatar
Lan
Default Re: (integracura)
I have 17's and this is the pressure I run.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rcp &raquo;</TD></TR><TR><TD CLASS="quote">I thought it was 33 front and 35 rears? Someone correct me if i'm wrong.</TD></TR></TABLE>
You need more pressure in the front because of the extra weight.
Old May 12, 2006 | 09:53 AM
Rcp's Avatar
Rcp
Really? dang.. No wonder i have bad gas mileage... LOL
Old May 12, 2006 | 10:07 AM
Lan's Avatar
Lan
Default Re: (Rcp)
This will help! https://honda-tech.com/zerothread?id=1001286
Old May 12, 2006 | 10:45 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integracura &raquo;</TD></TR><TR><TD CLASS="quote">but does it matter, i have low profile kuhmo tires with 17" rims. </TD></TR></TABLE>
It doesnt' matter; the recommended 35F/33R is still a good place to start. If you then decide you want to change the pressures due to treadwear patterns, handling, ride comfort, etc, you can do so from there.
Old May 12, 2006 | 11:21 AM
1337whp's Avatar
lol kuhmo i got some stories about those
Old May 12, 2006 | 07:47 PM
i took out some air cuz i had like 41 psi in all the tires. now i have like 38 in all, but im gonna take out some in rear.
Old May 12, 2006 | 08:40 PM
Dc_John's Avatar
Don't know but i heard 32.5 all around is fine. i could be wrong, but thats what im running, i have 205/04/17s also. Air Expands when its hot so i would lower that 38psi of yours. Try Nitrogen in your tires. they keep their pressure better. its about 35 bucks a set
Old May 12, 2006 | 10:11 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (Dc_John)
38 psi is way too much.
35/33 works well but 32.5 all around isn't too far off. Make sure you measure when the tires are cold, meaning that the car hasn't been driven in a few hours and isn't sitting out in the sun, since driving or sunlight can heat up the air in the tires, increasing pressure.
Old May 13, 2006 | 12:29 AM
DA9ReMiX's Avatar
32 all around works for me. 38 psi is too much.. you're gonna start wearing the middle part of ur tires
Old May 13, 2006 | 10:32 AM
Robstunner4's Avatar
Default Re: (DA9ReMiX)
32psi is what discount tire will put in ur tires unless they look in ur door jam and find different
Old May 15, 2006 | 08:04 PM
damn i better change it to 35/33 then, cuz i usually always get around 300-350 miles everytime. In the door jam it says 29psi in front and 29 psi in back which is for stock tires though.
uglybanter
Feb 6, 2008 04:35 PM
cyang08
Mar 13, 2006 04:43 AM
HondaGus
May 21, 2004 11:54 PM
DailyBlown
Feb 24, 2004 03:59 AM
Integra187
Mar 21, 2002 07:38 AM
