rocker arm assembly gasket
Old May 12, 2006 | 08:07 AM
janz3n's Avatar
Default rocker arm assembly gasket
my engine is leaking from the bottom of the spark plug hole and from what iv read its the rocker arm assembly gasket. is this the proper name for this gasket ? if not what is it? because i want to fix this soon and the proper name will help me find the gasket easier.
Old May 12, 2006 | 08:20 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: rocker arm assembly gasket (janz3n)
https://www.hondapartsdeals.com/honda_parts.php
Look under engine>cylinder head
It is described as an o-ring {91301-PJ7-000 O-RING (31X2.5) }
Old May 12, 2006 | 08:23 AM
janz3n's Avatar
Default Re: rocker arm assembly gasket (88DXCRX)
theres no picture . ya an o ring is what id need to seal up the leaking holes. but if i went to a parts place would i ask for a rocker arm assembly o ring?
Old May 12, 2006 | 08:25 AM
janz3n's Avatar
thanks alot.
Old May 12, 2006 | 08:27 AM
janz3n's Avatar
only shows two there.. and the two they show are the two holes with the most oil. wonder if num. 1 and 4 have them aswell
never mind says req. quant. 3 for 16 and 1for 17
Old May 12, 2006 | 10:19 AM
Donkey85's Avatar
you need to get the valve cover gasket set which usually include the spark plug seal gaskets or the o-rings if u will
Old May 12, 2006 | 11:05 AM
88DXCRX's Avatar
Default Re: rocker arm assembly gasket (Donkey85)
Click on the pic after it loads for better resolution:
On a d15 or d16,there are also o-rings under the rocker assembly
that seal the spark plug holes besides just the ones on top.
janz3n; Sorry the pic I posted the first time would not work..
Old May 13, 2006 | 08:03 AM
janz3n's Avatar
thanks alot i just orderd some from that website because my parts store didnt know what i was taling about.
Old May 13, 2006 | 08:11 AM
shortyz21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by janz3n &raquo;</TD></TR><TR><TD CLASS="quote">thanks alot i just orderd some from that website because my parts store didnt know what i was taling about. </TD></TR></TABLE>
valve cover gasket kit.
u were calling it something weird thats why..
Old May 13, 2006 | 09:47 AM
MENACE's Avatar
Default Re: rocker arm assembly gasket (shortyz21)
Tube seals, or spark plug tube seals. should come with a VC gasket set.
HiGhGuY
Jul 30, 2014 10:13 AM
invisible
May 12, 2009 04:48 AM
scott1ct
May 21, 2007 12:00 PM
nafreak
Oct 9, 2006 08:36 AM
RicedREX
Feb 9, 2003 09:31 AM
