PM6 chipping question
Old May 12, 2006 | 02:54 AM
zenon8890's Avatar
Default PM6 chipping question
hi HT, i wanna chip my pm6 to run vtec and a better fuel map. i'm using d15b vtec, is there a chip can do that?
i'm doing my turbo setup at the moment so i want a complete setup chipping
Modified by zenon8890 at 4:06 AM 5/12/2006
Old May 12, 2006 | 03:05 AM
downest's Avatar
Default Re: PM6 chipping question (zenon8890)
http://www.pgmfi.org
Old May 12, 2006 | 06:48 AM
nelsmar's Avatar
90-91 ecu required. you can use the AC out line to activate Vtec, with a relay. make sure you know hat yoru doing with a solder/desolder iron first. i can show pics of myn. there are few setupts out ther eyou can use http://www.pgmfi.org check ti out. most of the guys that made tuning software are on there.
if yoru boosting dont forget your wideband, your gonna blow **** up
(i bitch about this daily. but try my town... 1nce a month someone turbo's a civic here..... 1nce a month they blow it, after telling me they did no fuel system bur it runs "strong as hell" ...)
Old May 13, 2006 | 01:48 AM
zenon8890's Avatar
Default Re: PM6 chipping question (nelsmar)
thanks man, but i'm not trying to make my own chipping i dont know how to do that, i'm asking about where to buy a chip that can make my ecu ready for boost?! i dont wanna blow my engine for now
Old May 13, 2006 | 08:53 AM
iphatcrxi's Avatar
Old May 13, 2006 | 01:01 PM
nelsmar's Avatar
doenst work that way, you need to chip your ecu.... and TUNE it to your applicaiton. each motor flows idfferently and you get diff air flow in it. compresse / burns diffrently. so your air to fuel ratios will be off. i mean sure you could use someones tune and it will be alot better than nothing. but the timing might be to agressive or... they might be runnign leaner because of treament / aftermarket internals. alot into it.
best thing. find someone with a wideband, and have them help you do a basic tune that is slightly rich. and slightly les agressive timing for safty.
or get a FMU. works outa box. fairly cheap. i dont care how everyone says they suck. not as good as a tune but it adds fuel and for alot of people. its the easiest route. and the cheapest. i my self would just save for the wideband and learn to do a basic tune. but or some the 400$ vs 100-150$ is a tad much.
just my 2 cents. hope it helps : )
5thgencivic
11
Jul 14, 2011 04:00 PM
fryman
Oct 18, 2008 11:54 PM
zenon8890
Oct 5, 2006 03:43 PM
604Squad
Apr 28, 2006 05:42 AM
ef_hybrid
24
May 15, 2005 06:22 PM
