HID wiring installation (on winter beater, not a Honda)
I installed HID on my winter beater, a Daytona, but I thought this wiring info would come in handy on this forum as well since the same company sells bolt-in stuff for accords and civics...
I ordered a set of replacement 4656 quad lamps from http://www.spitzkraft.com
They arrived well packed and undamaged.
The kit included all the wiring and hardware...
...and bulbs, which came pre-installed in the assemblies. I took this Philips D1S bulb out of the low beam housing so it could pose for this photo.
I started by swapping out the high-beams, since the new high beams were halogen and a snap-in replacement (sort of - more on that later)
The clear lens polycarbonate halogen replacement is about the same size as the old sealed beam unit, and comes with a harness adapter for plug-and-play electrics.
now I just had to attach the harness adapter, and the high beams were done.
Fits like a glove. Now to mount the ballasts!
The Daytona features metal panels behind the lights that protect it the engine bay from front splashes, and these panels are further protected by overhangs. Because they're well forward of the engine, these front corner positions are also fairly cool, considering they're in an engine bay.
Electrics such as the ballasts are far happier in cool and dry positions such as this!
First, we have to make room on the driver's side. I took out the battery...
...then the coolant reservoir...
The ballasts will go in this corner. Eventually.
The MAF (Mass Air Flow) sensor and it's huge housing has to get out of the way.
A semi-hidden bolt. Oh, those wacky Chryco engineers!
Out she comes. This will make working on the front wall, and stringing the wiring harnesses, much easier.
With battery, coolant bottle, and MAF out of the way, there's tons of room to work.
Meanwhile, on the passenger side, all I had to do was drill holes and mount the ballast. I decided to do this side first, as it'll have harness running past the left side ballast later.
so far, so simple...
I ran the green wire, which plugs into the stock harness, and the bulb harness through a hole in the frame...
...and out beside the bulkhead.
There! Snug like bug in rug.
Connected up the harnesses to the ballast...
I repeated my ballast and light mounting efforts on the left side. You can see I ran the right-side harness up along the front edge of the radiator. The metal was shaped just right to act as a full-length retaining bracket!
Putting the MAF and coolant bottle back. You can just see the ballast beside and behind it. In the Daytona, there's about an inch and a half between the coolant bottle and the metal wall I mounted the ballast to, so the two don't touch.
Mounting the relays (I've since tidied up that harness overlapping the rear relay)
Each harness has two 20 amp fuses mounted in a fuse block, and a red (power) and black (ground) wire. The two blocks snap together to make a chain, seen to the left of the strut tower...
...and the red and black wires I bolted directly into the side battery terminals.
Well protected ballast (notice the overhang?)...
Clean install! Dirty beater car!
All wiring neatly tucked and secured, ballasts in cool, dry areas, relays and fuses safe and sound with their stock counterparts...
The new HID projectors stick out more than stock since they sit in the same buckets, but I think they look good.
Done!
a hasty shot, lights aren't aimed yet...
as seen from the front. Slightly blue, as expected of HID, but awesome visibility.
Done!
