Rough idle after beating on car. Any ideas?
Old May 11, 2006 | 06:36 PM
swifty4u's Avatar
Default Rough idle after beating on car. Any ideas?
This problem just started a few days again, after doing some runs at the track my car sounded really bad at idle, seemed like it was misfiring if the revs were under 2k. Above that, its fine, but it will almost stall out while idling, idle rough, and missfire while im trying to get going. After a bit of (soft) driving it will go away. Any ideas?
d16z6
zex 59300 cam
p28
intake, header, stock exhaust
92 cx hatch untuned
Old May 11, 2006 | 06:38 PM
99CivicSiBrian's Avatar
B A N N E D
Default Re: Rough idle after beating on car. Any ideas? (swifty4u)
maybe you melted a piston ringland. Thats how my turbo Si went down.
B
Old May 11, 2006 | 06:41 PM
swifty4u's Avatar
Default Re: Rough idle after beating on car. Any ideas? (99CivicSiBrian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99CivicSiBrian &raquo;</TD></TR><TR><TD CLASS="quote">maybe you melted a piston ringland. Thats how my turbo Si went down.
B</TD></TR></TABLE>
It only does it immediately after I beat on the car though, it will drive fine when I normally drive like a grandmom.
Old May 18, 2006 | 05:31 AM
NJcoupe's Avatar
Did it reallllll bad this morning too.
RE-CAP
92 cx hatch, d16z6, zex 59300, Stock p28 maps, intake,header, stock exhaust.
Car runs rediculously rich, and it idles like **** after its beat on.
Old Jul 2, 2006 | 04:53 PM
swifty4u's Avatar
Default Re: (dxcoupe.)
Anything guys? Changed plugs, checked cap and rotor..still doing it.
Old Jul 2, 2006 | 06:17 PM
CASTUDILLO01's Avatar
rec doing a compression test or leak down test may bent a valve
Old Jul 2, 2006 | 08:52 PM
ddd4114's Avatar
Default Re: Rough idle after beating on car. Any ideas? (CASTUDILLO01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CASTUDILLO01 &raquo;</TD></TR><TR><TD CLASS="quote">rec doing a compression test or leak down test</TD></TR></TABLE>
yeah
Old Jul 2, 2006 | 10:34 PM
Vtec4me's Avatar
sounds like a bent valve, compression test
Old Jul 5, 2006 | 07:45 AM
swifty4u's Avatar
Default Re: (Vtec4me)
Since so many have recommended it I might do a comp test, but why would a bent valve only become noticeable after I drive the car hard? The car is 100% fine when I drive it normal.
And also, the misfiring doesnt gradually get better, if I let it idle for a few minutes, it will crossover to a stock perfect idle from the rough lumpy misfire idle quickly not gradually.
racinmason85
Jan 19, 2008 09:15 PM
defkid999
Oct 17, 2006 10:12 AM
NJcoupe
May 23, 2006 05:47 AM
AThiker
Mar 19, 2005 09:50 PM
Chris N
Dec 4, 2003 09:40 AM
