NEED AXLES FOR ZC TRANNY
hit the junkyard and get some 90-3 teg axles
look on http://www.car-parts.com to locate junkyard near you
If you don't feel like removing the dust shield rings from inside your steering knuckles (a must if you use 90-93 axles). Get a pair of 90+ integra inner joints and put those on your axles. If you don't have the ZC intermediate shaft, get 2 Right Hand side inner joints. If you've got the int. shaft, you'll need a L & R 90+ inner joint, and another Civic/CRX short axle to put the Left Hand joint onto (splined all the way).
Since you live in the land of milk and honey, where the weather is always perfect, you probably don't need to be as concerned about the dust/gravel/sodium chloride getting into your front hub bearings....In that case, you need a pair of 90-93 INtegra axles (only if you have the ZC intermediate shaft).
crxguy406
Jun 29, 2013 09:50 PM
Jays91DXhatch
11
May 10, 2005 07:11 PM
