Rate my welds
Old May 11, 2006 | 05:38 PM
C_H_A_D's Avatar
Default Rate my welds
What do you guys think. It was a practice for my welding certification. It 3/8 flat stock with a 1/4 gap. The sides are cut at a 45 degree angle. That is why there is a 1/4" plate welded on the bottom. I can just fill in the gap with as much weld as possible. I am told they cut them in 1" strips. The pull it bend it and x-ray it.
Old May 11, 2006 | 07:45 PM
dfoxengr's Avatar
Default Re: Rate my welds (NINJASWORD)
stick i assume? what rod are you using. looks very very uneven like youre not moving in a straight line and dont have a steady pace.
how is your body positioning when you weld?
Old May 11, 2006 | 07:53 PM
k24em2's Avatar
Default Re: Rate my welds (dfoxengr)
What position is this? What rod? 7018?
Old May 11, 2006 | 08:24 PM
9295EJ-t's Avatar
looks cute... it will only get better!
Old May 12, 2006 | 02:29 AM
C_H_A_D's Avatar
Default Re: (9295EJ-t)
the rod is a 106. Its very similar to a 7018. Part of the reason it looks uneven is where I stopped and started me passes below the final passes. Oh this is also a flat weld.
I am going to try it again at work today or Monday I hope the next one looks cleaner.
Old May 12, 2006 | 08:34 AM
k24em2's Avatar
Default Re: (NINJASWORD)
Are you doing a 3 pass weld? Your consistancy needs practice, but that will come with time. The bead profiles are uneven....What size rod are you using? 1/8?
Old May 12, 2006 | 12:09 PM
C_H_A_D's Avatar
Default Re: (k24em2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k24em2 &raquo;</TD></TR><TR><TD CLASS="quote">Are you doing a 3 pass weld? Your consistancy needs practice, but that will come with time. The bead profiles are uneven....What size rod are you using? 1/8?</TD></TR></TABLE>
5/32 Its about 6 or 7 passes.
EF9_TryMe
Welding / Fabrication
Feb 5, 2012 06:08 PM
DXK Eg
Mar 28, 2007 06:03 PM
TIGboy
Nov 15, 2005 12:20 PM
nitekidsef9
Dec 6, 2004 03:56 PM
FeatherWeight
14
Nov 10, 2004 11:16 AM
