why is a dyno done in 4th gear
Old Apr 10, 2002 | 10:58 PM
dallandra's Avatar
Default why is a dyno done in 4th gear
can someone explain?....what happens if its done in 1st or 2nd gear ?
do turbo cars or eg V8's have an advantage over 4cylinders if dyno'd from 4th gear (more torque ?)
Old Apr 10, 2002 | 11:11 PM
Mike95lude's Avatar
Default Re: why is a dyno done in 4th gear (dallandra)
You want a gear that is closest to 1:1...which is 4th in most 5 speeds like our Preludes. I dyno'ed higher in 4th than 3rd too.
Old Apr 10, 2002 | 11:45 PM
dallandra's Avatar
Default Re: why is a dyno done in 4th gear (Mike95lude)
1:1 ...what ratio is that in regards to?
Old Apr 11, 2002 | 04:17 AM
dcb0821's Avatar
I think that is a ratio of drive gear to follow gear.
Old Apr 11, 2002 | 08:24 PM
CBR's Avatar
CBR
Default Re: why is a dyno done in 4th gear (slowlude)
1:1 ratio means that whatever speed your crankshaft is turning, your transmission(RWD) or transaxle (FWD) should be turning at the same speed. There is no gear reduction. What goes in goes out.
Old Apr 12, 2002 | 09:50 AM
Chronic139's Avatar
New User
1:1 means in most basic terms that your crankshaft is turning the same speed as the drive wheels.
Old Apr 12, 2002 | 01:00 PM
Greyout's Avatar
Default Re: why is a dyno done in 4th gear (Chronic139)
um guys that never can happen with a 4.27 final drive.
Rocket
46
Sep 30, 2010 10:42 PM
cruzersi99
18
Aug 24, 2005 09:08 AM
kchungb17a
Oct 30, 2004 08:20 PM
Maxime
Jul 25, 2002 10:50 AM
TypeR0149
Mar 19, 2002 02:59 PM
