Should I get Hondata?
Old May 11, 2006 | 05:12 PM
redej878's Avatar
Default Should I get Hondata?
OK I have a 97 civic with an OBD-IIa LS swap. I have been told by a local tuner that one of the first things I should upgrade is the ECU (I.E. AEM, Hondata, MS).
I haven't decided if I want to go boost or a nitrous setup. He said a good set up would be an OBD-II - OBD-I convertion harness and and OBD-I ECU with a hondata setup. What do you guys say?
Old May 11, 2006 | 06:47 PM
b18sihatch's Avatar
Default Re: Should I get Hondata? (redej878)
would be a good idea, but a better idea is to first decide if you are going for high compression (na) for boost (fi) then that will better help you on picking the right ect and other modifications to your motor
Old May 11, 2006 | 09:12 PM
redej878's Avatar
Default Re: Should I get Hondata? (b18sihatch)
I am pretty sure I want to go boost just because the LS is a great platform, and to go LS vtec would cost more than I could dish out
Old May 12, 2006 | 01:08 PM
redej878's Avatar
Anyone else have input?
Old May 12, 2006 | 01:17 PM
trickeng's Avatar
hondata will be your best bet and is always a good idea for squeezing every once out of your set-up.
keep in mind this also takes a competent tuner...
Old May 12, 2006 | 10:46 PM
redej878's Avatar
Default Re: Should I get Hondata? (trickeng)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trickeng &raquo;</TD></TR><TR><TD CLASS="quote">keep in mind this also takes a competent tuner...</TD></TR></TABLE>
HAHA this I know
turbotegra@10psi
Southeast (Sales)
Nov 29, 2008 09:55 AM
92integraVTECgsr
May 2, 2008 11:32 PM
93egboosted
Mar 14, 2008 04:38 PM
Avenged7x
May 14, 2005 09:58 AM
