screeching/whistling/scrhistling noise when starting engine
Old May 11, 2006 | 03:59 PM
axtran's Avatar
Default screeching/whistling/scrhistling noise when starting engine
when i start up my GSR, it sounds like something is spinnin' wildly loose/crazy. like it whistles and screeches real loud, only when i start up... sounds like it coming from driver's side of car? give it about 4, 5 seconds it goes away, only happens when i start the car. anyone have this happen before? other than that, car runs butter smooth, flawless. thanks!
Old May 11, 2006 | 04:00 PM
axtran's Avatar
may i also add, would worn/torn tie rod / tie rod boots be the culprit in this situation? i think my passenger's side tie rod could be a little screwed up. my axles are freshly rebuilt so i dunt think they are it, but i could be wrong... thanks for the input guys!
Old May 11, 2006 | 04:24 PM
SicilianSpeed42's Avatar
Default Re: (axtran)
sounds like a belt to me....maybe power steering related?
Old May 11, 2006 | 04:52 PM
Jap_Spec_Imports's Avatar
Default Re: screeching/whistling/scrhistling noise when starting engine (axtran)
Yea, that was my problem. Its a loud screech right? Well I cut my PS and that was the end of it...lol
Old May 11, 2006 | 04:56 PM
EH339's Avatar
Check your belts.
Old May 11, 2006 | 05:22 PM
SiYouLater's Avatar
Default Re: screeching/whistling/scrhistling noise when starting engine (EH339)
CHeck the timing belt.
Old May 11, 2006 | 05:56 PM
axtran's Avatar
looks like timing belt is rubbing on the stupid plastic piece on the side. is it possible to just get rid of this plastic piece? and by plastic piece i mean the belt goes under the valvecover where the cams are, and down to the main pulley... there's a plastic shroud that looks like it has been rubbing on my belt... i want to just rip it off
Old May 11, 2006 | 06:03 PM
AgentofDarkness's Avatar
I wouldn't take the plastic thing out, it keeps the rocks and other road crap out of your timing belt. If a rock ever gets in your timing belt you will have a very bad day.
Old May 11, 2006 | 06:09 PM
axtran's Avatar
man didn't think of that. thanks. sheesh how to push this belt back... think think think ... prob gonna have to dismantle it eh?
tonykdee
Honda Civic (2001 - 2005)
11
Dec 15, 2009 10:43 AM
walsh22
May 10, 2007 12:29 PM
Babakarab
Apr 16, 2007 12:29 AM
-iLLuZioN-B18C1
Jan 8, 2003 06:16 PM
98TypeR
Aug 1, 2001 08:30 AM
