clutch and throttle cables
Old Apr 10, 2002 | 10:14 PM
S13 slide's Avatar
Default clutch and throttle cables
ok right now im running my civic clutch cable and throttle cable, i 've read arguments about being able to use these parts when you swap an Ls motor in, but my clutch cable and throttle cable has a bit of slack in it that i cant get out. so which parts would be the correct to use? thanks
Old Apr 10, 2002 | 10:18 PM
Urban Business
Guest
Posts: n/a
Default Re: clutch and throttle cables (S13 slide)
all stock cables will work, throttle is suposed to have slack. clutch was a bitch to get on for us but does have a little slack. you can adjust that tho
Old Apr 10, 2002 | 10:54 PM
S13 slide's Avatar
Default Re: clutch and throttle cables (TorteX)
well i ment on the throttle cable is, i can press the pedal a little bit and it only pulls the cable and the butterfly doesnt get pulled. does that explain it? thanks
Old Apr 10, 2002 | 11:11 PM
Urban Business
Guest
Posts: n/a
adjust the nut used for tension adkustment
Old Apr 11, 2002 | 08:42 AM
Hayasa15's Avatar
so when you do a swap you dont need to swap in the teg cables?
madgeo
Jul 22, 2009 03:41 PM
ironchef25
10
Jan 20, 2004 12:26 PM
sCeRaXn
Mar 3, 2003 05:46 PM
CRexcellence
Dec 11, 2002 03:12 AM
BoostinDC2
Feb 17, 2002 05:41 PM
