STOCK TACH - Doesnt Work - Wire Is Intact - Why? Getting 15.1 V - Diagnose?
Old May 11, 2006 | 02:12 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Default STOCK TACH - Doesnt Work - Wire Is Intact - Why? Getting 15.1 V - Diagnose?
In my 88 Crx si, my tachometer no longer works, I had it out last summer and it worked fine, car was stored for a year and now its out, the rest of the cluster works just **** but the tach goes knowwhere
I spliced into it for my shift light before I got the car running, realized the tach wasnt working, so I unconnected the shiftlight and it still doesnt work
The tach wire was never cut, just stripped away the plastic and connected the shiftlight, what would cause this?
When I put the voltmeter on dc I think, im pulling 15.1 volts on the tach blu wire when the car is on, normal?
Old May 11, 2006 | 03:19 PM
_Keith_'s Avatar
Maybe the tach is broke... put in another cluster from a friend or somthing
Old May 11, 2006 | 04:41 PM
PINKS's Avatar
Default Re: (_Keith_)
Old May 11, 2006 | 05:36 PM
doublethink's Avatar
Default Re: STOCK TACH - Doesnt Work - Wire Is Intact - Why? Getting 15.1 V - Diagnose? (PINKS)
pu tit to a/c you should see a nice variation to the voltage that changes just like a tach would.
making this up:
idle 1.8
1/2 5.7
WOT 10
something like that should give you an idication of the output being correct. easiest way would be swapping another cluster in, but obviously not everyone has em laying around.
streetrider002
Aug 8, 2011 11:57 AM
eljah0426
Mar 14, 2011 05:59 PM
Fatcobra
Apr 17, 2007 05:20 AM
PINKS
10
May 12, 2006 07:50 AM
zccr-xsi
Nov 3, 2005 03:15 PM
