[FS] H22 - H22A4 '97 Prelude - $700 Great Compression - PICS!!!
I'm listing this for a friend who keeps on listing this on EBay and keeps on getting deatbeat bidders. I don't know why he didn't list this on HT. Here's his desciption:
(THE MOTOR IS IN MINNESOTA)
Engine comes with 4-2-1 stainless header and cat deleting resonator. Engine is in good running condition, a compression check was done the day of removal They were as follows Cylinder #1 225 Psi, Cylinder #2 225 Psi Cylinder #3 230 Psi Cylinder#4 225 Psi . I drove the car the day I removed the engine there is nothing mechanically wrong with the engine, the throttle positioning sensor is missing you can find one on eBay from a F, H, B, D, series motor early 90’s and up will work also needs to have a stud drilled out in bottom half of header were the two pieces come together. The engine has 94,083 miles on it, timing and balancer belts were replace at 89,000 miles distributor cap, rotor, plug wires, and spark plugs have also been replaced since then. This engine has never had a turbocharger or supercharger installed on it, there is allot of life left in this engine. ECU and wire harness are not included. Engine will be fastened to a pallet using ratcheting straps and covered with plastic wrap to secure a safe arrival Feel free to ask any questions. Thanks for looking, Derrick
He had it in a '98 CL 2.3, but couldn't figure out the wiring and gave up on it. He swapped the 2.3 SOHC back it. That's why he's selling.
Here's the pics I took.
I'm not sure if I'm able to post EBay actions on HT, but you can probably find it. If you have any other questions reply to this thread or PM me.
This guy who's selling is a good guy and if you're looking to get it shipped he can do it for $300-$400 (you can set something up with him if you want). Also if you want to call him and talk about the motor his number is (218)343-9836 his name is Derrick.
Thank all!
Aaron
Thank all!
Aaron
OverBoostDemon
Nov 3, 2009 09:25 AM
