Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Adjustments to Front and Rear shocks to compensate for worn out tires in Auto X
Old May 11, 2006 | 01:59 PM
schumi's Avatar
Default Adjustments to Front and Rear shocks to compensate for worn out tires in Auto X
Falken Azenis on my GSR are kind of worn out ....not completely but I would say 30% left on two tires and 40% on other two. Liitle low on cash so can not go for another set for the next month or so.
Question is......
Which set of tires should be up front the one with more tread? (30% set or 40% set)
I have Koni Yellows and Ground controls coil overs (400 F , 450 Rear) all around . What's the best shocks settings to compensate for worn out tires? ( more stiff up front and soft on back etc?
I am trying to make the best out of the situtaion... so please don't tell me that my only option is to get another set of tires!!!!!
Thanks
Old May 11, 2006 | 02:03 PM
Mugenlude's Avatar
More tread on the front. And I don't think you have to adjust shocks too much, typically we would shave tires down to 50% or so. We found that our older sets of RT-215's were faster than our new full depth tires.
Old May 11, 2006 | 02:09 PM
Targa250R's Avatar
be professional
Default Re: Adjustments to Front and Rear shocks to compensate for worn out tires in Auto X (schumi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schumi &raquo;</TD></TR><TR><TD CLASS="quote">Falken Azenis on my GSR are kind of worn out ....not completely but I would say 30% left on two tires and 40% on other two.</TD></TR></TABLE>
That's not worn out, that's prime condition.
Old May 11, 2006 | 02:24 PM
schumi's Avatar
Default Re: Adjustments to Front and Rear shocks to compensate for worn out tires in Auto X (Targa250R)
Ok....thats good news.
What shock settings for Koni Yellows ( how many turns from Full FIRM)
How much pressure for front and back
Old May 11, 2006 | 06:37 PM
schumi's Avatar
I usually run 45 at front 28 psi in the rear. With konis 3/4 turn from full soft front, 1 turn from full soft in the back
Old May 11, 2006 | 06:49 PM
CRX Lee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by schumi &raquo;</TD></TR><TR><TD CLASS="quote">I usually run 45 at front 28 psi in the rear. With konis 3/4 turn from full soft front, 1 turn from full soft in the back</TD></TR></TABLE>
Start there but be prepared to add more rear rebound stiffness to dial in more oversteer as needed. Don't be surprised if you find yourself up near max on the rears in autocross (too much for the street) but near mid-range on the fronts.
Old May 12, 2006 | 09:39 AM
schumi's Avatar
Default Re: Adjustments to Front and Rear shocks to compensate for worn out tires in Auto X (CRX Lee)
Thanks......
mrlegoman
Sep 29, 2009 11:25 AM
aeolus
Jun 25, 2002 04:33 AM
Flux
May 19, 2002 03:15 PM
