98 accord possible fuel problem
Old May 11, 2006 | 11:42 AM
Nikos's Avatar
Default 98 accord possible fuel problem
My 98 accord has 140K miles. It would crank but not start one morning… So I took the fuel rail out to see if fuel is going through it and after I did that, and put it back.. it started… Since I was in there, I replaced the regulator. I drove the car for a day straight and it was doing ok… Next morning again, car would crank but would not start… After a few days, I try again and it starts…
I guess it must be the fuel filter that is located in the gas tank… My question is… since I am going to be replacing that filter, should I replace the fuel pump as well?
Anyone thinks it is something else? I cannot duplicate the problem.. It seems to happen once the car has been left overnight.. Gas tank is full.
Thanks for any advice!
No codes, etc…
Old May 11, 2006 | 03:45 PM
BLKFLSH's Avatar
Default Re: 98 accord possible fuel problem (Nikos)
Sounds like a fuel pump, or main relay problem. Next time it doesn't want to start listen for the fuel pump running when you turn the key to second position (before cranking). The fuel pump is supposed to prime when you turn the ignition on (run for two seconds, then stop).
Old May 11, 2006 | 04:02 PM
johnny872005's Avatar
definately a fuel pump I think... almost same problem with our suburban
Old Jul 6, 2006 | 11:03 AM
Nikos's Avatar
Default Re: (johnny872005)
ok, replaced the fuel pump...
When it is hot outside, car runs... When it is cold in the morning, it doesn;t want to start no matter how long I crank it.
Where is the fuel pump relay located at on a 98 accord LX? I cannot find it.
How can I check the main relay?
Any help would be greatly APPRECIATED!
cholder919
Feb 4, 2013 07:14 AM
4door93civic
Jan 3, 2011 10:53 PM
civicb16eg
Mar 6, 2009 04:08 PM
5lugcivic
May 26, 2007 01:51 PM
mastar91169
Jun 30, 2006 12:35 PM
