Breakin off a 2.0L ls/vtec
I have a new build engine a 2.0L ls/vtec.Butt can i use a oem type r feulmap to breakin the motor with orginal fpr and injectors?Or is this a not a good plan?I hope someone can help me with this,because i have to drive the car to the tuner.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackpearlcivic »</TD></TR><TR><TD CLASS="quote">I have a new build engine a 2.0L ls/vtec.Butt can i use a oem type r feulmap to breakin the motor with orginal fpr and injectors?Or is this a not a good plan?I hope someone can help me with this,because i have to drive the car to the tuner.
So you plan to drive the car to the tuner and then switch everything over when you get there?? I would say the easiest but more expensive and SAFE thing to do is rent a trailor and borrow a truck and make your life alot easier
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96 GSR-T »</TD></TR><TR><TD CLASS="quote">
So you plan to drive the car to the tuner and then switch everything over when you get there?? I would say the easiest but more expensive and SAFE thing to do is rent a trailor and borrow a truck and make your life alot easier</TD></TR></TABLE>
Oke than i am going to do that because i dont wanna mess up my engine.
dan's integra
Oct 11, 2006 04:23 PM
