I think water is leaking in my R
Old Apr 10, 2002 | 09:42 PM
hungsteR's Avatar
Default I think water is leaking in my R
When it rains I think water gets in my R. But the only spot that seems to get wet is behind the drivers side seat under the floor mat or on the floorboard. There's not a lot of water but it's just a little damp.
There aren't any holes in the roof or anything like that so what could it be? I just wanna figure it out so it doesn't cause anymore problems.
Old Apr 10, 2002 | 09:52 PM
Art Vandeleigh's Avatar
Default Re: I think water is leaking in my R (hungsteR)
thats crazy!! wish i had an answer for ya. have you checked under the car?
[Modified by cali-r, 6:53 AM 4/11/2002]
Old Apr 10, 2002 | 09:54 PM
PureTeg420's Avatar
make sure your trunk where the spire tire is isn't full of water. One time i had a leak and there was like a foot of water that splashed out sometimes since I have the rear seat removed. Damn tailight....
Old Apr 11, 2002 | 05:23 AM
hungsteR's Avatar
Default Re: I think water is leaking in my R (PureTeg420)
Any other suggestions guys?
Old Apr 11, 2002 | 05:35 AM
pleiades nutz's Avatar
Hung, check to see if any of the rubber seals in the door are torn. If its damaged water can end up in weird places........this was the case with my corrado, took me for ever to figure it out.
Old Apr 11, 2002 | 05:38 AM
Back in Black's Avatar
Rather OG
Perhaps the former owner, if there was one, had a bolt in cage/bar in the car and didn't plug the holes?
Old Apr 11, 2002 | 05:49 AM
hungsteR's Avatar
Default Re: I think water is leaking in my R (darth vadeR)
I'm pretty sure that's not the case
Old Apr 11, 2002 | 07:27 AM
hungsteR's Avatar
Well I check the spare tire area is dry and the seams around seals around the door seem to be ok. Damn anything else?
Old Apr 11, 2002 | 08:36 AM
Default Re: I think water is leaking in my R (Buzz8400)
Maybe the butt plugs under the carpet came loose. If you go under the car and look you should see some rubber gromets under there, poke at them and see if they are solid.
Second the lines for the rear squirter could have come loose or broke see if the thing sprays fluid (also smell the carpet, what does it smell like?)
Third have you been using the A/C? maybe that leaked into the passenger area?
Hope I helped...
I dont think that that much water would soak up from the bottom of the car. I bet you it is the rear window squirter thingy line or a leak from "up top" somewhere so enough water can leak in and saturate the carpet.
Old Apr 11, 2002 | 11:06 AM
hungsteR's Avatar
Default Re: I think water is leaking in my R (nighthawkR618)
I'll check it out this weekend when I have some more time. Thanks for the help guys, if there are any more ideas just keep them coming.
milanoredgsr
Feb 24, 2008 11:14 AM
Wiseguy619
Nov 11, 2006 03:49 PM
PatrickGSR94
Jan 30, 2005 02:38 PM
hOndafienD 04
Dec 9, 2004 11:13 AM
Arvid
May 11, 2003 08:35 AM
