94 civic with a B18C1 swap
Ok, I just dropped the 94 JDM GSR B18C1 into my 94 Civic Lx 1.5L non-vtec. I am having problkems with the wiring harness. I was told that I can use the stock harness from the 1.5L non vtec that came in the car. I also have a chipped P28 ecu for it. The car will not start after hooking up the harness and it is throwing the code 13: Atmospheric pressure. Am not not doing something right? Is there anything else that needs to be wired in?
dunno bro make sure timing is right all plugs are hooked up right with nothing crossed. Grounds also. Is it jus cranking and attempting to start or what. Ensure u run that wire for vtec
ok, found out that the timing was off by 180 degrees, thats why it wouldn't start. Now I may have to take the guy I bought the engine from to court because he lied about the condition of the engine. The crank and all bearing are completely messed up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SystemShock »</TD></TR><TR><TD CLASS="quote">ok, found out that the timing was off by 180 degrees, thats why it wouldn't start. Now I may have to take the guy I bought the engine from to court because he lied about the condition of the engine. The crank and all bearing are completely messed up. </TD></TR></TABLE>
bummer story, hopefully things go well in court
180 degrees off, where the cams upside down while the crank was at TDC?
