Want to Buy Want to Trade/Want to Buy
WTB: VAFC OBD2 Harness
Old Apr 10, 2002 | 09:28 PM
Audipwr1's Avatar
Default WTB: VAFC OBD2 Harness
just as it says
looking for a prefab clean harness to connect a vafc into an obd2 integra gsr
Old Apr 10, 2002 | 10:52 PM
B00ST2nR's Avatar
Default Re: WTB: VAFC OBD2 Harness (Audipwr1)
doesnt the VAFC come with all the Harness to fit OBD1 and OBD2??
Old Apr 10, 2002 | 11:25 PM
Jaker's Avatar
What year Integra? I am making some for S2000's right now, and could make you one for your GSR. Plug and play if you'd like, or set up with 11 wires with tags that show the color of the wires on the V-AFC pigtail ready for you to solder to. Heatshrink supplied.
Here are 3 pictures:
The 1st one is the one ready for attaching the V-AFC pigtail. Don't worry, that band of masking tape is just for shipping.
The 2nd and 3rd pictures are the plug and play adapters. You would have to send me your pigtail to have it attached to the adapter.
[Modified by Jaker, 12:42 AM 4/11/2002]
Old Apr 10, 2002 | 11:38 PM
vpc's Avatar
vpc
New User
Default Re: WTB: VAFC OBD2 Harness (Jaker)
thats a pretty f'n clean pigtail jaker
Old Apr 10, 2002 | 11:50 PM
Jaker's Avatar
Default Re: WTB: VAFC OBD2 Harness (vpc)
I've made 36 of those things in the last month, and I've got about 30 more to make right now. It is a shitload of work, I have to do everything. Cut wire, strip wire ends, crimp on terminal, cut heatshrink, slip heatshrink onto wire, trim pins on ECU connector, tin wires, tin leads on ECU connector, solder wires to ECU connector, shrink heatshrink tubing, insert pins into connector bodies, test adapters, make wire tags, tag wires, pack adapters, take adapters to post office. I've put about 130 hours into the job so far. Probably about another 100-120 hours to go.
Old Apr 11, 2002 | 08:14 AM
Audipwr1's Avatar
what do you charge for the first option (just the connectors (solder ready))
its a 96 integra
Old Apr 11, 2002 | 08:36 AM
Jaker's Avatar
Go look here for info on the group buy.
Old Apr 11, 2002 | 08:52 AM
Audipwr1's Avatar
look where!!!
Old Apr 11, 2002 | 09:05 AM
darkfx's Avatar
i'd need one for my hondata, do you make those?
Old Apr 11, 2002 | 09:22 AM
Jaker's Avatar
They are $140 shipped if you pay by money order, and $145 shipped if you use Paypal. The price is the same for both versions. Contact me by e-mail if you want more info.
[Modified by Jaker, 10:22 AM 4/11/2002]
Old Apr 11, 2002 | 09:24 AM
Jaker's Avatar
Default Re: WTB: VAFC OBD2 Harness (darkfx)
darkfx - I e-mailed you.
Old Apr 11, 2002 | 09:25 AM
ElectronMan's Avatar
Where in the hell do you find all of those OBD2 plugs?!
Liquidgsr
Sep 5, 2012 07:57 AM
Blazeone
Feb 15, 2004 12:01 PM
B2FiNiTY
Dec 11, 2002 10:39 PM
Dave-ROR
Oct 18, 2002 10:48 AM
