Some transmission problems with Accord
Old May 11, 2006 | 09:45 AM
B16Jacques's Avatar
Default Some transmission problems with Accord
I have a couple problems with my accord.
D4 is flashing, TCS light is on and check engine light is on. I haven't got the f faintest idea what it could be.
I don't have alot of knowledge about Honda's so if anyone has any idea what it could be it'll be much appreciated
Old May 12, 2006 | 10:16 AM
webej551's Avatar
Default Re: Some transmission problems with Accord (B16Jacques)
what year? D4 is a transmission problem. Check engine light is an emissions problem. Go to Auto Zone and have them put on diagnostic reader for free(If you have one around). Should pull up code. Look up code to see what it is, and go from there. If you have a 5 generation and under 150,000 miles, you can probably get all the work done for free, plus a free tune up.
How long since you changed your engine oil. sometimes if you go over recommended maintenance schedule, your check engine light will come on.
Old May 12, 2006 | 11:06 AM
Ross 2.0's Avatar
In a Junkyard near you.
Default Re: Some transmission problems with Accord (webej551)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by webej551 &raquo;</TD></TR><TR><TD CLASS="quote">what year? D4 is a transmission problem. Check engine light is an emissions problem. Go to Auto Zone and have them put on diagnostic reader for free(If you have one around). Should pull up code. Look up code to see what it is, and go from there. If you have a 5 generation and under 150,000 miles, you can probably get all the work done for free, plus a free tune up.</TD></TR></TABLE>
Somewhat right the second part is complete crap.
Bottom line you need to have the codes pulled (trans codes are best pulled by the dealer.
Oh wait your talking about a John Deere Tractor right?
Old May 13, 2006 | 09:32 AM
webej551's Avatar
Default Re: Some transmission problems with Accord (MooGoCow3)
What part is complete crap?
Hondalina
Dec 13, 2010 02:39 PM
Spartoons
Jul 9, 2007 05:44 PM
92acclude
Aug 28, 2004 09:52 PM
ACCORD2000
Oct 10, 2001 05:31 AM
