Spark Plug Change- Help!!!
Remove the strut tower brace and the bracket that holds the AC line to the brace. The line should move around enough to get the ignition coils out at that point. If you still have problems, you could unbolt the brackets that hold the AC line to the body on each side I suppose. I've never had to go that far to get them out personally. You can "flex" the line a little without hurting it as long as you don't go nuts with it.
thanks for the help and it worked. Unfortunately we thought we could bend the ac line enough without removing the strut bar. WE WERE WRONG!!! but its ok, we tore the o-ring in the ac line so it leaked out all of the refrigerant. Refilled it for 20$ and learned how to replace spark plugs. Car runs great now.
thanks
thanks
