wiring vtec on a p28...
Old May 11, 2006 | 08:11 AM
.BigSexy's Avatar
most hood white kid
Default wiring vtec on a p28...
ok, so I am picking up my h22 in a couple of weeks, and I am also picking up a p28. the question is, do I wire vtec to the same pins to for the p28 as I do for the p13?
i found this on a thread this is the p13...
Top side w/ the sticker
---------------D6-------------------------------------A4---
l --------------\/---- -------------- -------------------\/-- l
l l oo . . . . . . . . o ll . . . . . . . . ll oo . . . . . . . . ooo l l
l l oo . . . . . . . . o ll . . . . . . . . ll oo . . . . . . . . ooo l l Front of Car
l -------------------- -------------- ----------------------- l
Floorboard side
(Hope that turns out right.)
A4 = Vtec solenoid------------------Large pin
D6 = Vtec Oil Pressure Switch-----Small pin
and then here is the p28....
onl;y difference I see is the knock sesonor, does the obd1 h22 not have a knock sensor?
Old May 11, 2006 | 12:46 PM
flyrod's Avatar
Default Re: wiring vtec on a p28... (egcoupe94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egcoupe94 &raquo;</TD></TR><TR><TD CLASS="quote">do I wire vtec to the same pins to for the p28 as I do for the p13? </TD></TR></TABLE>
Yes, assuming everything is all OBD 1. The only wiring change to make when running a H22 with a chipped P28 is to take the EGR stuff off and throw it as far as you can. Good luck with the H22 install.
Old May 14, 2006 | 05:54 AM
NoVALude's Avatar
Do you have emmissions testing/regulations there in TN?
Old May 14, 2006 | 12:40 PM
.BigSexy's Avatar
most hood white kid
Default Re: wiring vtec on a p28... (NoVALude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NoVALude &raquo;</TD></TR><TR><TD CLASS="quote">Do you have emmissions testing/regulations there in TN?
they do in Davidson County(Nashville) but I live in smith county on the outskirts where they dont.
Old May 14, 2006 | 12:41 PM
.BigSexy's Avatar
most hood white kid
Default Re: wiring vtec on a p28... (flyrod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyrod &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, assuming everything is all OBD 1. The only wiring change to make when running a H22 with a chipped P28 is to take the EGR stuff off and throw it as far as you can. Good luck with the H22 install.</TD></TR></TABLE>
why is this?
slammed4dreg
Jan 27, 2009 10:49 AM
reynosop
Apr 16, 2007 07:17 AM
.BigSexy
May 11, 2006 06:42 PM
South Bay Surfer
Apr 17, 2003 01:03 AM
Chuji
Jan 27, 2003 08:20 PM
