del sol fender wells
i made a topic about this once before and never really got an answer
i have teins basic damper kit on my del sol with 205 40 17 tires my wheels are sitting about an inch out of the fender if u look at it from the side
there is a spot inside the fender where the medal meets and it folds down inside there and when im on the highway if i hit a big bump my wheels will bottom out...
i wanted to lower my car a little bit more for a little more aggressive look the car almost looks like its not even really lowered... is there a way to remove those fender wells or something?
yup, u just gotta unscrew or pop out all the fasterners. You also gotta remove the mud flaps if you have some. The linings go all the way to the front of the bumper, BTW.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolMarine »</TD></TR><TR><TD CLASS="quote">its all metal in there its just screwed in?</TD></TR></TABLE>
No the plastic is what is screwed in and is removeable. For the actual fenders, if they are in the way, you need to roll them outwards. There are tools for this or alot of people use the baseball bat method where they put a baceball bat between the tire and fender well and gently roll it on the tire causing the fenders to flair outwards.
a posted this a long time ago and never really got a better response... figure ill try again
still hits in there on the big bumper when i turn anyone else have this problem?
rustboy
Apr 27, 2004 05:52 AM
