OBD2 LS VALVE COVER ON OBD1 MOTOR LS
OK I have an obd2 96-00 ls valve cover with the pcv hole in the top.but my 95 ls motor has it by the intake manifold.what do i use to cover the hole.
If it is simply a hole, can you find a small short bolt that will screw into the hole maybe?? Or one that fits in but maybe glue it in or something along those lines?
I say this because one of the extra breahter holes on my intake I put a small bolt into and uses hotglue to hold it in...
Just an idea, but not intended to be the best answer. I'm sure someone will come up with something probabily more fit for this situation.
you can either use a solid rubber grommet or even better is just to leave the pcv valve there and vacuum cap it.
or if you really want to lose it, take it off and tig weld it, then refinish in wrinkle paint
Cracked out suggestions... j/k lol!!! Go out and buy a crankcase breather filter. Or a pvc rubber nipples...
crankcase filters --- http://www.knfilters.com/vent.htm
rubber nipples ---
http://images.google.com/imgre...a%3DG
rubber nipples ---
