Accord '93 Front wheel noise
Old May 11, 2006 | 06:26 AM
istabrak's Avatar
Default Accord '93 Front wheel noise
Greetings,
The driver side fornt wheel started to make a noise that icreases with speed similar to the noise that the old car axle used to make when it has a problem.
The noise is very evident on speeds 70 km/h and above.
I took a quick look at the cv boot but to my surprise it was not damaged.
Could the cv axle produce such a noise even though the boot is still intact?
Moreover, there is no clicking noise when making a full right/left turns.
If not then could it be the front bearing or some thing else?
Is there a way to test an verify?
Thanks,
Ista
Old May 11, 2006 | 06:59 AM
S CARTER's Avatar
Default Re: Accord '93 Front wheel noise (istabrak)
definitely check the wheel bearing.
On your car its kind of a pain in the *** to replace because its pressed on the hub, and the hub is bolted to the rotor.
Old May 11, 2006 | 11:40 AM
istabrak's Avatar
Default Re: Accord '93 Front wheel noise (S CARTER)
Thanks for your reply.
What is the best way to replace the bearing? should I take out the hub and take it to shop to get the new one installed in?
Or is there another way to DIY at home?
regards,
Ista
curvenut
Jun 17, 2014 12:32 AM
SHystrdyGSRtdy
Mar 4, 2013 01:24 PM
Steve LeB
Oct 28, 2011 11:58 PM
dc2doi
Oct 15, 2007 11:23 AM
istabrak
Jun 8, 2006 01:10 PM
