Core Support On 1992 DA Question
Old May 11, 2006 | 04:59 AM
Rajin's Avatar
Default Core Support On 1992 DA Question
I'm right in assuming the 90-93 Core Supports have no change, that it was just the outer fascia (front bumper) that changed in the 92 transition year?
I had a wreck and my core support is toast and I found a 90 Support for 33 bucks at Pull-A-Part there wont be any problems using this will there?
Old May 11, 2006 | 06:51 AM
Rajin's Avatar
Default Re: Core Support On 1992 DA Question (Rajin)
Anyone?
Old May 11, 2006 | 06:59 AM
Snizzoop's Avatar
The mounting points moved a little bit when they redesigned the bumper. You will need the mounting blocks for the same year core you are using.
HTH
Old May 11, 2006 | 10:50 AM
Rajin's Avatar
Default Re: (Snizzoop)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Snizzoop &raquo;</TD></TR><TR><TD CLASS="quote">The mounting points moved a little bit when they redesigned the bumper. You will need the mounting blocks for the same year core you are using.
HTH</TD></TR></TABLE>
Now that sucks, I need to have a direct replacement.
I'll just remove the mounting blocks along with it.
Old May 11, 2006 | 04:24 PM
Rajin's Avatar
Default Re: (Rajin)
Figured it out. 90-93 Core Supports are the same only difference is in the bumper support itself
EX-T
Jun 26, 2007 11:13 AM
Rajin
Welding / Fabrication
Aug 17, 2006 07:15 AM
PnkRokCountryboy
Dec 27, 2005 05:20 PM
elitesi8
Sep 22, 2005 06:56 AM
