Just did a baseline run today...need opinions...
Old May 11, 2006 | 01:33 AM
K-Spec's Avatar
Default .:Baseline Run Today:. need opinions...
So I went to Church Automotive and did a baseline run today...
I have 154,000miles and the compression is 185,180,185,180. Here are my current specs:
(stock internals)
AEM CAI
SMSP Header
Magnaflow 2.5" Hi-flow cat
Mugen Catback
Unorthodox SS Pulley set
With the mileage/compression of the engine and the current setup, is this ok?
I'm going to have the engine fully rebuilt soon...just need to find a shop...
Old May 11, 2006 | 03:10 AM
pentaq's Avatar
Default Re: .:Baseline Run Today:. need opinions... (khalal538)
Kinda low IMO for flywheel power. If it's wheel hp, then OK...
Old May 11, 2006 | 06:09 AM
flyrod's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 &raquo;</TD></TR><TR><TD CLASS="quote"> SMSP Header </TD></TR></TABLE>
Not bad, but when Corey somehow made 200WHP with that header on an otherwise stock H22... though I have not seen anyone repeat his results.
Anyway, thanks for posting up your results. What kind of setup are you working on? There is a prelude dyno thread around here somewhere, you could add your info to it.
Old May 11, 2006 | 07:07 AM
oranginal's Avatar
Default Re: .:Baseline Run Today:. need opinions... (flyrod)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyrod &raquo;</TD></TR><TR><TD CLASS="quote">Not bad, but when Corey somehow made 200WHP with that header on an otherwise stock H22... though I have not seen anyone repeat his results.
Anyway, thanks for posting up your results. What kind of setup are you working on? There is a prelude dyno thread around here somewhere, you could add your info to it.</TD></TR></TABLE>
doesn't look like you have anything to tune with, thinking that might help out a little.
just wondering if Corey have a 2000/fifth generation?
differant generations might yield differant results.
i have a fourth gen and was wondering what kinda results to expect with this header.
good to finally see a post.
Old May 11, 2006 | 07:26 AM
Eksmashin23's Avatar
Old May 11, 2006 | 07:56 AM
ludatic98's Avatar
Default Re: .:Baseline Run Today:. need opinions... (Eksmashin23)
not bad but i expected to see bigger gains with those mods
good to see a post for the 5th gen
Old May 11, 2006 | 08:10 AM
chitownrida's Avatar
not bad ..
alot of miles
Old May 11, 2006 | 08:31 AM
K-Spec's Avatar
Default Re: .:Baseline Run Today:. need opinions... (pentaq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq &raquo;</TD></TR><TR><TD CLASS="quote">Kinda low IMO for flywheel power. If it's wheel hp, then OK...</TD></TR></TABLE>
It's to the wheels.
Anyway, thanks for posting up your results. What kind of setup are you working on? </TD></TR></TABLE>
Well...the header was designed for the specs that I "will" have, not a stock motor.
My new specs will be:
AEM CAI
Stock TB
Euro-R Intake Manifold w/ Hondata Heatshield
Euro-R Camshafts w/ Fidanza Adjustable Cam Gears
Supertech or RM valvetrain kit
p28 w/ Hondata S300 tuning
Type-S Pistons OS bore
SMSP Header (built to these specs)
Magnaflow Hi-flow cat 2.5"
Mugen Exhaust (will change it to SMSP custom exhaust because current piping is not 2.5")
Unorthodox SS Pulley Set
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oranginal &raquo;</TD></TR><TR><TD CLASS="quote">
I have a 2001 Prelude running on Mobil1 Synthetic for most of the engine's life.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludatic98 &raquo;</TD></TR><TR><TD CLASS="quote">not bad but i expected to see bigger gains with those mods
good to see a post for the 5th gen </TD></TR></TABLE>
Shawn from Church said that I am running very rich and because of the stock IM's secondary, the torque curve at 4,000rpm dips down. That will be fixed once I get the Euro-R IM going. As for tuning the car w/ these mods, Shawn said that I would've been at 200whp. Plus this thing does have 150k miles on it.
But ya, thanks for all your inputs. Let me know if my future setup looks good or if you recommend going with something else feel free to chime in.
Old May 11, 2006 | 10:04 AM
94Vtecluder's Avatar
Yea i'd suspect tuning is holding you back here a great deal, so I wouldn't worry to much yet.
Old May 11, 2006 | 06:28 PM
K-Spec's Avatar
Default Re: .:Baseline Run Today:. need opinions... (94Vtecluder)
ya, i also have a little bottleneck going...2.5" hi-flow cat into a 50mm mugen piping...then after the resonator it's 60mm to the twin-loop and finally out the tip.
Old May 12, 2006 | 12:26 PM
mgags7's Avatar
keep in mind its a dynapack and they read like crap compared to dynojets, way high, way low, theyre all over the place....
Old May 12, 2006 | 01:46 PM
darkspector's Avatar
Default Re: .:Baseline Run Today:. need opinions... (apeng09)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by apeng09 &raquo;</TD></TR><TR><TD CLASS="quote">looks low to me.
usdm engine i'm presuming?
and why are you running unorthodox ss pulleys?</TD></TR></TABLE>
Why shouldn't he be?
Old May 12, 2006 | 02:18 PM
K-Spec's Avatar
Default Re: .:Baseline Run Today:. need opinions... (darkspector)
Yeap USDM and what's wrong with them? They work fine for me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">keep in mind its a dynapack and they read like crap compared to dynojets, way high, way low, theyre all over the place....</TD></TR></TABLE>
so which dyno should i use for accuracy?
Old May 12, 2006 | 03:26 PM
Dameltajo's Avatar
wow nice numbers and you arent even tuned yet.....
i just made 182hp with I/H/E with a tuned vafc
i really need to get some better headers this megan's arent helping at all.
Shell@Castrol
Sep 27, 2008 11:36 PM
Jeff_B
Mar 12, 2007 02:49 AM
slickshifter
Honda S2000
10
Feb 6, 2007 05:29 PM
VSBB6
88
May 30, 2005 11:04 PM
bluemex
Nov 8, 2003 01:14 AM
