all motor setup, ls/vtec, mild build, 200whp goal...
Old May 11, 2006 | 12:45 AM
g2lsvtec's Avatar
Default all motor setup, ls/vtec, mild build, 200whp goal...
well im building a ls/vtec to go in my friends 91 civic hatch si. im building a basicly stock block ls/vtec... heres what i plan
ls block, honed and bored to 82mm
b16 p30 jdm pistons
new barings, rings seals and gaskets
gsr oil pump
arp rod bolts and head studs
gsr water pump and timing belt
ctr crank pully
skunk 2 cam gears
mildly ported and polished b16 obd1 head
aebs intake manifold
68mm tb
3" itr aem intake
crower stg 3 cams
kms dual valve springs and titanium retainers
345 prelude injectors
converted to obd1 and tuned with crome pro
dc sports 4-1 header.. for now but modded with 2.5" dp
2.5" full rsr exhaust
b16 lsd hydro transmission
act clutch and fidanza i think 9 or 10p flywheel
and thats about all for now, soon to get a new header and dyno time, this will be street tuned by a local crome tuner. also geting a tracktion bar for wheel hop issues haha
tell me what u think, the crower stg 3s he has are like skunk 2 stg 2 cams, there older cams, the head came off his b16... but id like to know what everyone thinks of this setup. hes hoping for 200whp and mid-high 13s with slicks. thanks for looking, pics up soon of the build.
Old May 12, 2006 | 08:39 AM
RaceCarRyne's Avatar
Default Re: all motor setup, ls/vtec, mild build, 200whp goal... (g2lsvtec)
id go with the skunk 2 pro 1 cams unless you decide to raise compression to like 12 to 1 and even more with the crower 3s
Old May 12, 2006 | 12:54 PM
UncleD's Avatar
Default Re: all motor setup, ls/vtec, mild build, 200whp goal... (DC2jdmIntegra)
82mm P30 pistons??
Old May 12, 2006 | 01:03 PM
MR_Ek4's Avatar
Default Re: all motor setup, ls/vtec, mild build, 200whp goal... (clean rice)
let us know how those kms things work out, but i would suggest a spring recomended to handle the lift of a crower 3 like a crower spring just my .02 cents
Old May 12, 2006 | 11:00 PM
g2lsvtec's Avatar
the kms valve springs and retainers are made for the lift and duration made by these cams, i checked with them on the phone, rated to 11k also, they say your bottom end will go out before these do... it should be around 12.1.1-12.6.1 compresion with 82mm p30 pistons, decked b16 head... and the cams arent recent cams, there about 5-6 years old, not as much lift i belive as the new stg 3 cams... dont make any more than sk2 sg2s,
but ya thats about it, any other comments.. ive checked over alot of stuff, he already has the built head, hes ran it on his b16 block before, thats y were gona run the same stuff again, he ran the cams with that valvetrain for 10k+ on his b16 reving to 9800rpm. so everything should be fine -blake
Old May 12, 2006 | 11:33 PM
bks84's Avatar
Loved
how do you have an 82mm P30 piston? The biggest stock size P30 I believe is 81.25
Old May 13, 2006 | 01:42 AM
LSVTEC 91 Civic's Avatar
Banned
Default Re: (4sd4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2lsvtec &raquo;</TD></TR><TR><TD CLASS="quote">hes hoping for 200whp and mid-high 13s with slicks. thanks for looking, pics up soon of the build. </TD></TR></TABLE>
High 13s? ****.. I ran 13.3 @ 99 with 190whp and my LS tranny...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4sd4dr &raquo;</TD></TR><TR><TD CLASS="quote">how do you have an 82mm P30 piston? The biggest stock size P30 I believe is 81.25</TD></TR></TABLE>
I believe Nippon makes P30s, PR3's, and ITRs in 82mm
They aren't OEM Honda pistons, more like replicas..
Old May 13, 2006 | 02:06 AM
bks84's Avatar
Loved
Default Re: (LSVT3K 91 C1V1C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVT3K 91 C1V1C &raquo;</TD></TR><TR><TD CLASS="quote">
They aren't OEM Honda pistons, more like replicas..</TD></TR></TABLE>
yea, i knew nippon did.. but that wouldnt make em JDM or OEM [like you said]
was a bit confused...
Old May 13, 2006 | 02:51 AM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4sd4dr &raquo;</TD></TR><TR><TD CLASS="quote">yea, i knew nippon did.. but that wouldnt make em JDM or OEM [like you said]
was a bit confused... </TD></TR></TABLE>
Maybe the original poster considers Nippon pistons "JDM" because they are Made in Japan y0...
I guess.. lol
Old May 13, 2006 | 05:58 AM
D-Rob's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2lsvtec &raquo;</TD></TR><TR><TD CLASS="quote"> hes hoping for 200whp and mid-high 13s with slicks.</TD></TR></TABLE>
Hahaha, your buddy should have no problems hitting 'mid-13's.'
Look at my sig. Trust me. He'll be faster.
- Derek
Old May 13, 2006 | 01:29 PM
g2lsvtec's Avatar
Default Re: (D-Rob)
nice nice, ya i ment 82mm nippon racing pistons, not oem haha, but i was wondering, what kind and size of slicks should i put on it? what size wheels and stuff... i was thinkin 20 or 22" slicks not sure thow, what would everyone recomend? -blake
Old May 13, 2006 | 01:43 PM
D-Rob's Avatar
Default Re: (g2lsvtec)
22"
Old May 13, 2006 | 04:02 PM
g2lsvtec's Avatar
Default Re: (D-Rob)
haha thanks
Del Sex
21
Jan 10, 2008 09:08 PM
ticivc
Apr 24, 2006 05:58 AM
the.hamburglar
20
Apr 4, 2006 07:52 AM
