Short block replacement problem
Old May 10, 2006 | 09:32 PM
pki51's Avatar
Default Short block replacement problem
Howdy,
I recently replaced the engine in my 1991 Accord LX with one of those Japanese import engines. The place convinced me the smaller engine from a Civic would bolt right in and all of the parts would bolt on as well. That worked. However, now the engine will not idle. It'll start but the engine races wildly. I assume its a computer issue. Can I simply replace the Accord computer with one from a Civic? Any other ideas?
pki51
Old May 10, 2006 | 10:20 PM
momstaxi's Avatar
Default Re: Short block replacement problem (pki51)
no civic motors will fit a 91 accord but anyways,
massive intake manifold gasket vaccum leaks? a better description of the problem would help...
Old May 11, 2006 | 07:53 AM
notoriousB's Avatar
if you're running a civic motor with an accord ECU therein lies your problem.
install a civic ECU and then try again.
I would also check for vacuum leaks as suggested, but a DOHC 1.6l motor is not going to run right on an ECU made for a SOHC 2.2l motor!
Old May 11, 2006 | 08:31 AM
pki51's Avatar
Default Re: Short block replacement problem (notoriousB)
My mistake. I replaced the 2.2 liter engine with a 2.0 liter engine, NOT a Civic 1.6. The problem is that, while everything bollted back on perfectly and the engine fires right up, I can't seem to get the idle to come down. The engine races. There seems to be no access to the computer to check things (without a visit to the Honda dealer). Any suggestions. (Sorry about the misinformation. Civic indeed!)
pki51
Old May 11, 2006 | 09:33 AM
notoriousB's Avatar
2.0? is it a B20? if so the accord ECU probably won't control it right either. but a vacuum leak or bad IACV could be the culprit of a surging idle.
Old May 11, 2006 | 10:00 AM
v4lu3s's Avatar
RTFM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by notoriousB &raquo;</TD></TR><TR><TD CLASS="quote">2.0? is it a B20? if so the accord ECU probably won't control it right either. but a vacuum leak or bad IACV could be the culprit of a surging idle.</TD></TR></TABLE>
no its an f20a.
and the problem is probably a vacuum leak though ir wy too tight throttle cable...
mr0lg
Jul 28, 2011 04:54 PM
el_espiritu
Apr 17, 2011 11:25 AM
