B18c1/B16a2 Dyno !! Thanks intacracing!!!
Old May 10, 2006 | 09:04 PM
Ruben19's Avatar
Default B18c1/B16a2 Dyno !! Thanks intecracing!!!
i dynoed my motor today at intec racing.
results came out very good.
the motor made 194whp and 139ft/tq
My set up.
B18c1 block bore 81.50mm
B16a2 head
11.5:1 Je pistons(11.3 cr)
Blox type b cams
Rc310 injectors
Blox intake manifold
64mm throttle body
P06 obd1 ecu
Supertech valve spring/retainers
Spoon 2p headgasket
Jdm Itr 4-1 header with 2.5'' collector ''' i can make more power with a better header"" and intake
Test pipe and full 2.5 cat back
Tune with chrome and cam gear set at (-2,0)
I love this motor
[IMG][/IMG] http://i67.photobucket.com/alb...e.jpg
Modified by Ruben19 at 10:14 PM 5/10/2006 [IMG][/IMG] http://i67.photobucket.com/alb...3.jpg
Modified by Ruben19 at 10:19 PM 5/10/2006
Modified by Ruben19 at 11:42 AM 5/11/2006
Modified by Ruben19 at 1:58 PM 5/12/2006
Old May 11, 2006 | 05:23 AM
Anti-Drama Queens's Avatar
u didnt need 2 upgrade fuel pump?
Old May 11, 2006 | 05:27 AM
flesh199's Avatar
Default Re: (mr_ducksauce)
nice for a stock pr3 head
Old May 11, 2006 | 08:01 AM
Ruben19's Avatar
stock fuel pump all the way.
fuel pressure was left at 39psi
Old May 11, 2006 | 10:21 AM
B18cHatch06's Avatar
Default Re: (Ruben19)
ive got a similar setup looking to tune soon but with an RMF narrow when it comes in ...nice numbers
Old May 11, 2006 | 01:20 PM
VTECJUN's Avatar
Default Re: (B18cHatch06)
Glad we could help you out. Cant wait to see what she will do with a header!
Old May 11, 2006 | 07:40 PM
Ruben19's Avatar
im looking forward to buy a better header but it will be after summer.
also a better intake and a bigger throttle body.
what size of throttle body would you recommend for this set up
Old May 11, 2006 | 09:18 PM
UncleD's Avatar
Great numbers Ruben! Put a good header on and have your Blox IM ported out and you're way above 200whp. Congrats
Old May 12, 2006 | 05:40 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: B18c1/B16a2 Dyno !! Thanks intacracing!!! (Ruben19)
Good numbers. nice job
Old May 12, 2006 | 06:43 AM
Ruben19's Avatar
Default Re: (clean rice)
you think the size of the throttle body is ok or should i go bigger.
Old May 12, 2006 | 08:11 AM
function83's Avatar
fuel pump........he wasnt cutting out on the dyno nor was he losing pressure.
I'm pretty sure he'll be fine. i'm not sure if this helps but his car is an 99 si comes stock with a b series.
But as soon he has fuel supply issues i'm pretty sure he'll put in a bigger pump.
xialbyix
38
Jun 5, 2008 03:31 AM
Ruben19
Jun 12, 2006 09:19 AM
Ruben19
Mar 14, 2006 12:38 PM
6ghatch
30
May 31, 2004 08:52 AM
White S2k
Oct 11, 2002 12:46 PM
