What removes ricer paint??
my buddie just got a ek coupe and the interior is painted white what can we use that will work wonders without harming the finish? anyone else buy a riced out car?
have you tried this? I tried bumper paint stripper from auto zone and it gets it kind of but damages the plastic a little
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Acetone (fingernail polish remover) should work as a good solvent</TD></TR></TABLE>
yeah. but be carefull because plastic IS a petroleum based product.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DelSolMarine »</TD></TR><TR><TD CLASS="quote">just sand them down and spray with black plastic spray paint mayb?</TD></TR></TABLE>
+1
99% of strippers (if not all) will leave their marks on the plastic
+1
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tytyguy »</TD></TR><TR><TD CLASS="quote">im assuming its spray paint. get a spray paint remover, i got this stuff from home depot. its called "spray paint remover"
but it worked good on my car. didnt leave marks or anything</TD></TR></TABLE>
If it's the same stuff as "goof off", I wouldn't use it on plastic...
but it worked good on my car. didnt leave marks or anything</TD></TR></TABLE>If it's the same stuff as "goof off", I wouldn't use it on plastic...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic9 »</TD></TR><TR><TD CLASS="quote">gasssolinaa</TD></TR></TABLE>
also dissolves plastic. That might even make napalm, I know it does with styrofoam.
I used oven cleaner, got the tip from my friend who does interiors. It worked very well. Too bad the POS that had the car before me sanded the parts(with what looks like 60 or 80 grit with as rough& deep as the scratches are) to make the primer/paint stick better
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by professor poon »</TD></TR><TR><TD CLASS="quote">also dissolves plastic. That might even make napalm, I know it does with styrofoam.</TD></TR></TABLE>
yes you are correct... but if you dont dunk it in and leave it there for a long period of time, it works well.
we did it to my friends vents. dab some on a cloth or something and rub it onto the painted part... then clean it off w/ water immediately.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elwuudz »</TD></TR><TR><TD CLASS="quote">acetone is powerful and dangerous stuff if not used correctly
u can clean something really good ... or burn right through it
you can ghet high off acentone too.
</TD></TR></TABLE>you can ghet high off acentone too.
