Power Locks Broken??
Ok heres the deal, I have a 1990 4 door accord EX...
Whenever i try to use my power locks on my drivers side, i hear a clicking noise in the door panel...
Whenever i try to use my power locks on the passengers side, i hear a the same noise in the DRIVERS side... I didn't wanna tear my door panel off and mess with **** when i didn't know what i was doing so....
Anyone got any ideas??
Thanks
Thanks
Sounds like it could be your door lock actuators
here's a test u could run.
Driver's Door Actuator Test
1. Remove the door trim panel.
2. Disconnect the 4-P connector of the actuator.
3. Test actuator operation by connecting battery
voltage to the No. 1 and No. 2 terminals.
Test the actuator in each direction, by switching
the leads from the battery.
CAUTION: To prevent damage to the motor, apply
battery voltage momentarily.
4. If the actuator fails to operate properly, replace it.
5. Check for continuity between the terminals in each
switch position according to the table.
lrhtech
Jul 13, 2015 05:30 PM
danb18c
Jan 20, 2008 05:49 AM
swminnesotan
Oct 7, 2004 07:05 AM
