sticking clutch
this should be in the accord section because it concerns an accord but i'm in here more often and it could pertain to a integra as well. as the title states my clutch is sticking. it use to be on and off but now it's on constant. the dragging i mean. it fells like the clutch is not being disengage all the way, make it hard to shift if at all. to drive it one has to be able to shift w/o the clutch. - or might as well because it feels like it. anyway, i'ver ruled out the hydralic system slave/master...what else could be it? if i did a clutch job, would that fix the problem?
sounds like you may have broken one or more of the springs in the clutch disc.
I did this in my Integra. It made it nearly impossible to shift after awhile.
