Map Sensor differnce on 93 h22a1 vs. 94 h23a ASAP!
Old May 10, 2006 | 06:20 PM
h22a193's Avatar
Default Map Sensor differnce on 93 h22a1 vs. 94 h23a ASAP!
is there any difference between the parts...friend swaped in my 93 h22a1 into his 94 si car...if you hit the trottle hard it stumbles badley at low rpm....but increasing throttle slowly there is no problem....plus it runs fine up top....are there differences in the years, or VTEC changeovers.....Thanks
Old May 10, 2006 | 09:21 PM
InvaderTrax's Avatar
Check your timing (ignition, then cam). Also check plugs/cap/rotor/clean injectors
Old May 11, 2006 | 04:06 AM
h22a193's Avatar
Default Re: (InvaderTrax)
did it all....
pynikal
19
Oct 26, 2007 12:16 PM
y-49
Aug 24, 2006 01:57 PM
5thGenFanatic
Dec 2, 2003 11:58 AM
