stock shocks
the lower shock bushing the back on the 92 is thicker than those on the 98. you can grind down the bushings to make the shocks fit, but from then on you will have to run 96-00 shocks. if youre ok with that then go ahead, otherwise i would suggest finding the proper shocks for your application
