toda vtec killers... why dont they use vtec?
It's actually JUN (as far as I'm aware of) that has the VTEC Killers and the reason they don't use VTEC is....when you use VTEC, it's there to seperate different profiles on the cam, the VTEC portion being the more aggressive cam. VTEC Killers basically keep you on the "VTEC" profile and eliminate the need for any type of cam X-over. Basically, they aren't very streetable.
See http://www.todaracing.com/B162.html
ok who has these in their daily driver? I know some crazy fool does. Black R must be awaiting their arrival.....
what kind of power figures are we talkin here? I'm curious
The point is to get rid of the VTEC System, which lessens rotational masses and weight in the valve train. Enables you to rev higher...(10k+).
Suprdave
[Modified by FusionITR, 9:48 PM 4/10/2002]
Actually, I believe the VTEC Lobe is ground off, and your always on the base lobe, which is huge...
Suprdave
Suprdave
Why even bother with low lobes on a truly race-only cam?The VTEC Killer kit does come with all the chit to remove the entire system
[Modified by itr009, 12:54 AM 4/11/2002]
i HAVEtheADVANtage
May 5, 2003 12:02 AM
Drinker
