D series clutch B series motor
Old Apr 10, 2002 | 07:46 PM
Kamin's Avatar
Default D series clutch B series motor
Is it possible? i want to take my car up to phoenix tommrow and im worried if my clutch dies at the track (because i have no money) is it possible to use the clutch off my d16z6 in my b16a (sir II)
Thanks
Old Apr 10, 2002 | 07:51 PM
EP3_05's Avatar
Default Re: D series clutch B series motor (KAMiN)
I am almost 100% positive that it will not work. Usually b series and d series parts are not interchangeable
Old Apr 10, 2002 | 08:15 PM
Kamin's Avatar
Default Re: D series clutch B series motor (91civic)
'usually' key word
looking through my helms it appears they have the same number of bolts on the flywheel and in the same general location
i KNOW someone has tried this before i need first hand experience!!!
Old Apr 10, 2002 | 10:47 PM
Jaker's Avatar
Simple answer: NO!
Old Apr 10, 2002 | 10:49 PM
poison's Avatar
ahh don't think so man, d series clutch is tiny......i think the B series pressure plate and clutch plate is just a lil bigger.
Old Apr 11, 2002 | 06:18 AM
JD_B18CDX's Avatar
Clutch failure is usually caused by the frcition disc not having enough material and starts slipping.
Thats all it is basically, a friction material (just like brakes).
I think as long as the friction disc has the same diameter, then i think it would fit.
As for the presure plate, the B series motor have stiffer springs to handle the extra Hps. Therefore, using a presure plate (if it fits) from a less powerful motor is not a good idea.
Friction disk is only $130. Plus machine shop of Flywheel for $35 bucks. 165 bucks total if you do the work yourself and you can beat the crap out of it again.
Transmission & Drivetrain
Mar 31, 2011 07:37 AM
