rod bearings size (color) for aftermarket rods
Old May 10, 2006 | 02:41 PM
Mervin's Avatar
Default rod bearings size (color) for aftermarket rods
Hey guys n gals!
Im currently researching exact bearing colors that need to go into the block.
Ive taken the block apart and found that the oem rods have number stamped on them which make up halve of the size they need respectively, in conjuction with the cranck codes. The OEM bearings didnt have any color on them whatsoever, they faded away, I guess thats something something 100.xxx miles will do!!
If ive done my research right then the codes on the rods can be thrown out of the window when replacing them with aftermarket rods right???
Ive been told that the aftermarket rods will all be green sized and that I only need the crank codes to determine the right bearing color?????
Ok, the real question is what bearings do I need in the end for a crank with the following codes:
cyl 1 - C4
cyl 2 - D4
cyl 3 - C4
cyl 4 - C5
I hope this makes any sense and that my information is complete.............please feel free to chime in if my initial research is wrong also!!!!
Block is sitting at a friends garage and I can get any other details you may need to help me..............
Thanks in advance
Mervin
Modified by Mervin at 10:31 PM 5/15/2006
Old May 10, 2006 | 05:21 PM
MotorMouth's Avatar
Default Re: rod bearings size (color) for aftermarket rods (Mervin)
Plastiguage and helms is what you need. Unless you use Eagle rods which I know for a fact have the same big end bore as stock rods, then you just use the same bearings.
Do yourself a favor and get the crank micropolished, and balanced with the rods.
Don't listen to anybody who says otherwise its the best investment for a high revving bottom end.
Goodluck. Other brands may also be the same big end bore as stock rods, I don't know I use the eagle 900hp rods with no problems(boosted b16 revving to 9500).
Old May 11, 2006 | 02:28 PM
Mervin's Avatar
Default Re: rod bearings size (MotorMouth)
Thx for the response!
Well I live in Suriname, South America and there arent any high tech motor builders, shops in my region (not even a dyno for that matter).
I alreay took apart the block to check on the colors..........now codes, and just need some reassurance on what sizes to order since I will be importing them myself.................the local Honda dealer never sold Preludes so he doesnt even have literature or specs on the engine, let alone parts............grrrrrrrrr
I just want to be sure that the colors Im gonna be ordering will be right...............whattabout ACL???
Heard that they will fit, but you will loose some reliability and strenghth since the specs will be a bit looser (or too tight..)
I hope someone on here can help me!!!!!
Merv
PS, I will be using eagle rods
Old May 11, 2006 | 04:38 PM
MotorMouth's Avatar
Default Re: rod bearings size (Mervin)
what are the bearing codes, what engine are you building. PM me the information, I can get you the color codes and make sure you have the right bearings.
You can use ACL but like you said you will lose some reliability. Honda has 5 bearing colors. ACL only has 3 sizes.
Cylinder 1 you need:BLACK
Cylinder 2 you need:BLUE
Cylinder 3 you need:BLACK
Cylinder 4 you need:???? I dont understand how you have C5, that looks like a typo.
LMK.
Old May 11, 2006 | 10:36 PM
k24em2's Avatar
Why does everyone insist that because ACL doesn't have a zillion different bearing sizes that they are any less reliable than OEM? If you put it together right you won't have a problem with reliability either way.
Old May 15, 2006 | 01:43 PM
Mervin's Avatar
Default Re: rod bearings size (k24em2)
Motormouth: thx for the response!!!!
The motor Im building is a 95 USDM H22A1
Building the entire bottom end with
JE 9:1 cr pistons
Eagle rods
New bearings
OEM headgasket
This all for a Garrett T3/T4 - .48/.68 turbo.............
Ill look up the code for cyl 4 again and post tomorrow it might be a typo since the codes are bearely readable, theyre stemped in very naro black lettering and the crank taps are goldisch-brown, so, ill recheck ait just to be sure.
Also, the oem rods that were on the crank all had codes but one........I found that strange also, the first three were 2, 3, 4 and the last one didnt have any code.......(the numbers that divide when you take the rod-end off.........
Anyway (K24em2), I would like to go OEM, just because they have better/wider clearance choices and durability is PROVEN!!!!!!!
One more thing, the Haynes manual stated 7 colors, with green being the middle sized.................I dont know if this is also true for the H22 (the Haynes was for another honda model.....)
Old May 20, 2006 | 04:34 PM
Mervin's Avatar
Sorry for the long wait...........
Ive gone by and checked the cyl crank tap, it does have C5 stamped on it...........all the stamps are in like fine black lettering..............
On the first tap (cyl 1) theres also C3 stamped in very thick ink.......
I doubt that taking a pic will reval the smaaler stamps, but I could try............
pls lmk if this make any sense!!!!
Merv
Old May 20, 2006 | 08:02 PM
DRIVENRacing's Avatar
i have heard alot of BS about acl's... but we run ACL race bearings in all our engines, and they give us no problems AT ALL.. this is 600+ whp cars as well
Old May 21, 2006 | 08:55 AM
PURPLETERROR aka BIGMATT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MotorMouth &raquo;</TD></TR><TR><TD CLASS="quote">Plastiguage and helms is what you need. Unless you use Eagle rods which I know for a fact have the same big end bore as stock rods, then you just use the same bearings.
Goodluck. Other brands may also be the same big end bore as stock rods, I don't know I use the eagle 900hp rods with no problems(boosted b16 revving to 9500).</TD></TR></TABLE>
Wrong, eagle rods do not have the same big end bore as stock honda rods. Eagle rods are sized at a honda 3, honda rods are sized 1-4.
Acl bearings are ok if you are within spec. I prefer to use honda bearings on all my personal and customer builds, its alot easier to get the clearances you want.
To the original poster, your best bet Is to get a helms manual for your vehicle, it will explain every detail you need.
Old May 21, 2006 | 06:02 PM
MotorMouth's Avatar
Default Re: rod bearings size (PURPLETERROR aka BIGMATT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR aka BIGMATT &raquo;</TD></TR><TR><TD CLASS="quote">
: </TD></TR></TABLE>
I guess I just got lucky, I've rebuilt 4 B series blocks, all have had number 3's
Sorry to the original poster.
Old May 24, 2006 | 02:33 PM
Mervin's Avatar
thx for all the responses..............
im leaning more towards the acl's since there are no reputable shops in my area (or country for that matter)..................any news on the C5 tap?
and how about this acl kit:
http://cgi.ebay.com/ebaymotors...&rd=1
pls lmk!
Merv
surfinjoe911
Feb 15, 2008 07:25 AM
blkb18
Feb 5, 2008 08:07 PM
svmnredracr
Jul 28, 2004 11:25 PM
civicguy
Mar 29, 2002 04:56 AM
