cam swapping
Old May 10, 2006 | 02:27 PM
b18bteg14's Avatar
Default gsr cams in ls motor?
would a gsr cam work in an ls head? and what kind of power would it make over the stock ls cams. valvetrain upgrade needed? just an idea that i thought could work...give some input
Old May 10, 2006 | 03:17 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: gsr cams in ls motor? (b18bteg14)
No. I don't know. Substantial.
Whole different ballgame.
Old May 10, 2006 | 05:13 PM
UncleD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bteg14 &raquo;</TD></TR><TR><TD CLASS="quote">give some input</TD></TR></TABLE>
You want to put vtec cams in a non-vtec head, you tell me how thats gonna work.
Old May 10, 2006 | 05:19 PM
b18bteg14's Avatar
the vtec part of the cam wont engage but the duration and lift are different on the gsr cam so ud think it might work
Old May 10, 2006 | 05:20 PM
UncleD's Avatar
Default Re: (b18bteg14)
Does a vtec cam have 2 or 3 different size lobes?
Old May 10, 2006 | 05:23 PM
b18bteg14's Avatar
its got the secondary vtec profile
Old May 10, 2006 | 05:29 PM
UncleD's Avatar
So 2 or 3?
Here, I'll help you...
Old May 10, 2006 | 05:30 PM
b18bteg14's Avatar
i'll go ahead and say 3...but ur talkin to the kid with the ls
since the gsr cam wont swap in wat brand of aftermarket cams do u think would work best for street use
Old May 10, 2006 | 05:34 PM
UncleD's Avatar
All stock vtec cams have 3 seperate lobes. One that it idles on, the "secondary" is a midrange lobe, and then you have the vtec lobe. If you're looking for ls cams I would look into Crowers or you might be able to find some JG's. Save your money and do a head swap, or do some mild cams and add a B16 or gsr tranny if you want your car to go faster.
Old May 10, 2006 | 05:38 PM
Dan Ruddock's Avatar
Are you talking about grinding the vtec lobe on a ls cam or putting the whole vtec cam in. If the whole cam that won't work all you have to do is count the cam bearings the ls head has 6 and the vtec has 5 it won't fit. Dan
Old May 10, 2006 | 06:25 PM
Yambor's Avatar
the bearing journals on the vtec cams do not line up with the bearing caps on the ls head..
Old May 10, 2006 | 08:05 PM
SkRiBLaH's Avatar
Default Re: (clean rice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">All stock vtec cams have 3 seperate lobes. One that it idles on, the "secondary" is a midrange lobe, and then you have the vtec lobe. </TD></TR></TABLE>
your 100% wrong. it uses the 2 lobes untill vtec, then uses the middle lobe.
Old May 10, 2006 | 09:08 PM
JDM_DA9's Avatar
Default Re: (SkRiBLaH)
the man is right
Old May 11, 2006 | 12:05 AM
UncleD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkRiBLaH &raquo;</TD></TR><TR><TD CLASS="quote">your 100% wrong. it uses the 2 lobes untill vtec, then uses the middle lobe.</TD></TR></TABLE>
Yeah no ****, I think I knew that guy.....way to state the obvious.
Old May 11, 2006 | 02:05 AM
rainforest's Avatar
clean rice you are right all 3 lobes use seperate profiles primary secondary and high lift. as oppose to the ls wich uses 2 of the same.
Old May 11, 2006 | 07:36 AM
TylerH's Avatar
Default Re: (rainforest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clean rice &raquo;</TD></TR><TR><TD CLASS="quote">All stock vtec cams have 3 seperate lobes. One that it idles on, the "secondary" is a midrange lobe, and then you have the vtec lobe. If you're looking for ls cams I would look into Crowers or you might be able to find some JG's. Save your money and do a head swap, or do some mild cams and add a B16 or gsr tranny if you want your car to go faster.</TD></TR></TABLE>
There are only two different profiles. The two primary lobes are the same and then a higher lift and duration is on the vtec lobe in the middle there is no primary, secondary, and high lift. There is only two different profiles not 3. A non vtec on has only one profile because it uses no change in duration or lift.
Old May 11, 2006 | 07:42 AM
SkRiBLaH's Avatar
Default Re: (TylerH)
on rainforest and cleanrice
Old May 11, 2006 | 08:56 AM
UncleD's Avatar
Tell me there are only two lobes here on these cams.
Modified by clean rice at 8:02 PM 5/11/2006
Old May 11, 2006 | 08:59 AM
UncleD's Avatar
This right here says it all you ****** stunna. Know what the **** you're talking about before you open your mouth guy. Jesus, talk about
Old May 11, 2006 | 01:16 PM
UncleD's Avatar
I gotta bump this up just so people can see that these guys think there is only 2 lobes.
Old May 11, 2006 | 02:55 PM
SkRiBLaH's Avatar
im sorry your feelings are hurt.
and also im sorry this concept is making your head hurt.
the 2 outer lobes are the primary lobes.
the single inner lobe is the vtec lobe.
quit getting all butt hurt.
Old May 11, 2006 | 02:58 PM
SkRiBLaH's Avatar
clean rice (10:01 AM 5/11/2006): Check out your thread genuis.
^ he rreaaaaally wanted me to see this....
Old May 11, 2006 | 09:13 PM
UncleD's Avatar
Yes Junior, I understand the functioning of a god damned vtec camshaft. It gets under my skin REAL fast when some ricer hopps on here and argues with people(you) like they know what the **** their talking about. I understand the term "primaries," but I'm seeing this as you and your sidekick Tyler saying that there are only 2 different sized lobes when obviously there are 3. And who the hell are the two of you thinkin you're gonna try to teach me something here?? You kids got a long ways to go, be careful who you're directing a "" towards, they just might be, and in this case are, worlds above you in knowlege. Please. Yes I do know that there are some cams out there that have only 2 different sized lobes, but we're talking about oem cams here...and they have 3. End this stupidity.
Old May 12, 2006 | 05:52 PM
El_Capitan's Avatar
You have got to be ******* kidding me! vtec cams have 3 different profiles LS cams have 2 and only 2. The cam journals on LS and Vtec cams are completely different. They cannot and will not interchange. The reason they have 3 is for swirl at low speed. one valve opens farther than the other to optimize burn at low engine speed. When the Vtec is engaged all 16 valves operate off the center lobe. I have pictures too if you want to argue more.........Newjack
Old May 12, 2006 | 07:49 PM
Downey's Avatar
dont waste your time with the "vtec" bullshit. Buy a set of crower 404's and be done!
