How long does it take to install a B16 in a hatch?
Cost wise I spent probably $2500 total. Thats with the motor being $2250 and new plugs, wires, water pump, timing belt and radiator hoses.
First time i did it it took me 2 days the second time 6 hours.
Make sure you make every wire with masking tape where they go or you will take an additional 2-3 hours just getting the electrical correct.
Also depending on your linkage and motor mounts to convert from a D series to a B series there could be a fitment issue so do some research and have all the right parts before you start.
From: new jersey home of wanna be's posers claimers ricers biters and where everyone fakes the funk
to pull a motor with no problems..under 2 hours if ya know what your doing.
just research!!
just research!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cibola »</TD></TR><TR><TD CLASS="quote">First time i did it it took me 2 days the second time 6 hours.
Also depending on your linkage and motor mounts to convert from a D series to a B series there could be a fitment issue so do some research and have all the right parts before you start.</TD></TR></TABLE>
this guy speaks the truth. my b16 1st time swap, a day and a bit with a friends help. 2nd time, 1/2 day for the swap to get it running, and another 2 hours another day to work out and clean up wiring
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VALET dude »</TD></TR><TR><TD CLASS="quote">4-5 hours max
EXACTLY... 4-5 HOURS MAX.. ITS EASY AS HELL.. JUST LIKE DOING A D SWAP.. EXCEPT U GOTTA CHANGE THE 2 FRONT TOURQUE MOUNT BRACKETS AND THE THROTTLE CABLE THAT ***** EASY
</TD></TR></TABLE>EXACTLY... 4-5 HOURS MAX.. ITS EASY AS HELL.. JUST LIKE DOING A D SWAP.. EXCEPT U GOTTA CHANGE THE 2 FRONT TOURQUE MOUNT BRACKETS AND THE THROTTLE CABLE THAT ***** EASY
Ditto, this is a very easy job. My first swap was a GSR in a coupe. Took 11 hours total until we were running up and downt the road in it. I have done quite a few for others since then and have it down to my quickest being 3 hours 45 minutes now start to finish.
