building gsr head
So I have been looking at my options. I want to do camshafts/valve springs and retainers/cam gears and i'm going to be puting this on a stock gsr block.I've looked and priced the Toda,buddy club and skunk2 I want like the stage2 something thats still able to be driven on the street but good on the drag strip with a little bit of spray what are some good setups that you guys have run. thanks jon
jon,
IF you are going to stick with the stock block, the Buddy Club Spec III+ with Supertech valvetrain would be be a good combination.
You want to have the proper sprign rate for the cam spec so it works well together.
that combo right there is good for the street and will hold some nitrous use as well.
