sensor by thermostat
what color should the wires going into the harness be, and how many wires is it, i lost it in my wiring somewhere. or hooked it up to the wrong sensor
i can not find the plug for the life of me, what is it next to when it comes out of the main harness???, can someone take a picture for me please, i really wan to get my swap running, but if my fans dont turn on that could be a problem
. any help is appreciated.
no, it shouldnt matter. on obdo motor the fan switch is on the back of the block on obd1 car the fan switch is on thermostat housing, it has nothing to do with the ecu it just turns the fan on thats it
ok that makes sense now to me thank you but i still have an issue as the plug is not the same, i can chage it but i need to know which wire needs to go on top and which needs to go on the bottom, i already extended the wires, so the only thing left is figuring out which wire goes where. anybody know?
thanks so much, it was really bothering me that no one seemed to know, could the fact that i did not have this sensor pluged in befor be the reason why everytime i turn on my car the temp sensor would max out?
Like Crx Jimmy said, the order doesnt matter
And as for your last question, the answer is yes. If the fan doesnt turn on, there is no way that the coolant in the radiator will cool down and your engine will just get hotter and hotter. After you connect the sensor, let the temperature go to the middle and wait a few more minutes until the fan turns on, just keep an eye out on the temperature gauge so it doesnt overheat.
Had th same problem we swapped a B18b into my rex I'm still OBD0 and my friend said I didn't need it well my fan never turned on and after a few runs at the track and let my car idle for a little it over headed and puked coolant...
the OBD0 sensor is on the back of the block had a rubber cover over it was 2 wire I though it was like brown and green/yellow but I may be wrong I had to extend the wires to reach the thermo housing, the sensor has the same plug as like 2 or 3 other so i just got one at the JY and r wired it...now my fan turns on but I also found a hole in my rad
so i just orders a new JK cross member and a alum rad and slim fan
I can get you some pics if you need HTH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loserkidwac »</TD></TR><TR><TD CLASS="quote">Had th same problem we swapped a B18b into my rex I'm still OBD0 and my friend said I didn't need it well my fan never turned on and after a few runs at the track and let my car idle for a little it over headed and puked coolant...
I can get you some pics if you need HTH</TD></TR></TABLE>
sure how much did it all run you
well I got a bunch of stuff, Alum 1/2 rad, 12"slim fan JK crossmember, and then B series head flange, T3 flange, and 5 bolt echaust flange to make a mani and DP all ran a little over $500 but well worth it, I am excited because I have Konis and GC coils and putting the ES bushings in soon too the car is gonna handle amazing, hoping to put some nice 60' times if i get traction
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Loserkidwac »</TD></TR><TR><TD CLASS="quote">well I got a bunch of stuff, Alum 1/2 rad, 12"slim fan JK crossmember, and then B series head flange, T3 flange, and 5 bolt echaust flange to make a mani and DP all ran a little over $500 but well worth it, I am excited because I have Konis and GC coils and putting the ES bushings in soon too the car is gonna handle amazing, hoping to put some nice 60' times if i get traction
where did you get the rad fan and crossmember from
</TD></TR></TABLE>where did you get the rad fan and crossmember from
----jdm B20b swap 91 teg 0bd0
tibss
Jan 31, 2008 11:28 PM
Vtec's My Anti-Drug
Apr 22, 2007 04:00 PM
VNTEC
Mar 15, 2004 04:50 PM
Project_ED8
Dec 1, 2003 09:59 AM
